Thread: i'm losing my mind... HELP
Results 1 to 6 of 6
  1. #1 i'm losing my mind... HELP
    wisconsin
    ok. first of all i'm new to this forum. i joined because i am seriously losing my mind trying to figure out what is wrong with my car. 2001 grand prix gt 3.8 v6... 124k miles.
    last summer i started having this problem. i will be driving and the tach will drop completely to zero. continues to drive just fine, but the RPMs stay at 0. once in awhile it will stall completely and shut off. it starts fine when i restart it, but obviously this is not a normal thing. when my mechanic hooks it up to his computer no codes come up. and of course every time he drives it there are no problems. last summer i replaced the fuel filter and then the fuel pump. it ran fine all winter so i assumed the problem had been remedied and that it was a bad fuel pump. however, about a month ago the exact same thing started happening again. driving fine, tach drops to zero, continues to run fine with RPMs at 0. occasionally the engine stalls and shuts off but it starts immediately when i restart it.
    does anyone have any idea of what the problem could be??
  2. #2 Re: i'm losing my mind... HELP
    Charles City, IA
    Your crank shaft position sensor is going bad, it is behind the crank pulley .
    SMGPFC Two Nipple General
  3. #3 Re: i'm losing my mind... HELP
    GT Level Member rolyat's Avatar
    OKC
    X2, CPS for sure.
    2000 GTP: autolite 104's, 180 t-stat, shift kit, open cone spectre, 1.9 rockers, polished TB, ported blower, SD headers, zzp mps/3.4 pulley, 42.5lbs injectors, Reptile tune
  4. #4 Re: i'm losing my mind... HELP
    Willoughby, Ohio
    X3 exact symtoms of a CPS
  5. #5 Re: i'm losing my mind... HELP
    Akron Ohio
    X4 Just replaced mine
  6. #6 Re: i'm losing my mind... HELP
    wisconsin
    it was the cps. thanks so much for the help!!
  1. Losing Coolant from Overflow tank
    By Suaveat69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2010, 10:00 PM
  2. Losing power to wheels...
    By Deebo in forum General Tech Discussion
    Last Post: 05-01-2010, 03:06 PM
  3. losing power and stallin
    By jessica lavoy in forum General Tech Discussion
    Last Post: 03-12-2010, 02:36 PM
  4. help make up my mind
    By ammojunkie in forum Off Topic Discussion
    Last Post: 12-23-2009, 01:16 AM
  5. Losing RPM Gauge while driving!
    By fuzzy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-04-2009, 03:01 AM
