Thread: Car not acellerating past 30mph
Results 1 to 9 of 9
  1. #1 Car not acellerating past 30mph
    May 2008
    anyone know about the tracking control sensors and petal acceleration sensors causing the car to go below 30mph?
    if so is there a way to disable these? heard the sensors to replace were spendy.
    the sense code errors were as reported:
    Co420 PCM
    Traction control not allowed, engine reduced power
    P125A
    p2125a > accelerator petal position # 1 & 2
    P2138A - APP Sensor correlation
    Thanks for any help on this matter.
  2. #2 Re: Car not acellerating past 30mph
    GTX Level Member webracin's Avatar
    Arkansas
    You may want to try and remove your TCS fuse under the hood. That may fix the problem until you can figure out whats wrong....Dont remove the TCC fuse though or you will be all screwed up...thats the Torque Converter Contol fuse.
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  3. #3 Re: Car not acellerating past 30mph
    May 2008
    Quote Originally Posted by webracin View Post
    webracin
    I checked for the TCS sensor but i couldn't find it. Any other sensor it could be listed under or tied too?
  4. #4 Re: Car not acellerating past 30mph
    Hoffman/Schaumburg, IL
    I would think ABS fuse??? of try under the dash it may be there
  5. #5 Re: Car not acellerating past 30mph
    May 2008
    I had an issue with something similar. The car would not accelerate past ~30 mph. I had a broken wire to a sensor near the front wheel (passenger, but sensors are near both wheels, not on the hub).
    It was intermittent (sometimes car would run fine, then slow down), only because the wire would make/break contact.
  6. #6 Re: Car not acellerating past 30mph
    May 2008
    It was intermittent (sometimes car would run fine, then slow down), only because the wire would make/break contact.[/QUOTE]
    What were you able to do till you fixed the problem? as far as fuses/sensors/wires and just be able to drive the thing?
  7. #7 Re: Car not acellerating past 30mph
    May 2008
    Quote Originally Posted by Bonvoi29 View Post
    I didnt do anything to it, the car would still drive. It would just not shift up to a higher gear, and if it did shift (when sensor/wire made contact), it would downshift again, rpm went up, car slowed down.
    I just didnt drive it for a few days, til I had time to look into another issue (leaking power steering line due to friction against another line). I just happened to notice the broken wire.
    Looking at diagrams, I think it was the sensor to the hub. But this was on a 97 SE, now I have a 00 GT.
    If you need any diagrams for anything, let me know, I'll email them or post here if I can.
  8. #8 Re: Car not acellerating past 30mph
    May 2008
    yeah if you wouldn't mind?
    my email is bonvoi29@yahoo.com
    Thanks I really appreciate it, this is for a 04 gt
  9. #9 Re: Car not acellerating past 30mph
    Barksdale AFB, LA
    If there's a diagram that he needs that you don't have, PM me. I have access to a fairly thorough database.
    2009 Subaru Impreza WRX STI
  1. Vehicles you have or have owned in the past
    By IndeedSS in forum Off Topic Discussion
    Last Post: 04-07-2015, 08:53 AM
  2. Pics i took over past two weeks 56k/\_/\_______
    By aquase in forum Off Topic Discussion
    Last Post: 01-04-2008, 06:27 AM
