Thread: What will i need to run mid 14's?
Results 1 to 18 of 18
  1. #1 What will i need to run mid 14's?
    Jul 2010
    New England
    I am planning on getting a cai, 3"dp and tuned pcm. Do you guys think I will be able to run around 14.3 to 14.6? Also If i decide i want to add to pulley will i need to get a new pcm?
  2. #2 Re: What will i need to run mid 14's?
    Apr 2009
    stockton ca
    Change your plan just a bit and you will be all good
    get headers (speedaddys) PCM(3800performance,intense,Reptile)
    make your own open cone theres a couple write ups
    do a 180 tstat,colder plugs, and a 3.4 pulley drop
    and you will be in 13sec teritory
  3. #3 Re: What will i need to run mid 14's?
    Donating Users shawn's Avatar
    rogers arkansas
    I had a hot air intake and a better tune than the factory and I ran 14.5 @ 94.. Then headers and a 3.4 and was runnin 13.9s@ 98.
    STOLEN XPZ SETUP WITH CNC PORTED HEADS!!
    13.76@99.60 on 3.4 setup
  4. #4 Re: What will i need to run mid 14's?
    Jul 2010
    New England
    Quote Originally Posted by TorqueAutoMotiv View Post
    I was thinkin about doing all that stuff, but I want to make my car last as long as possible because I spent all my money on it haha
  5. #5 Re: What will i need to run mid 14's?
    Apr 2009
    stockton ca
    A properly done pulley drop wont make your car fail just keep it maintained and dont beat on it and it will last
  6. #6 Re: What will i need to run mid 14's?
    rogers arkansas
    lol watch out for your tranny though that's gonna be your weakest link once you get a good tuned 3.4 setup.. I had it dyno tuned @ 237 whp and 267 ft tq with just the 3.4 setup b4 the SSIC and went through 3 tranny rebuilds. Currently on my 4th rebuild but I went to the track every weekend .. Bout 350 passes down the track since 08.. Turns out it was my valvebody all jacked up with sticky valves..
  7. #7 Re: What will i need to run mid 14's?
    Apr 2009
    stockton ca
    as i said your fine if you dont beat the piss out of it
  8. #8 Re: What will i need to run mid 14's?
    rogers arkansas
    exactly wat he said you should be fine lol .. And plus my tranny had ton miles on it..
  9. #9 Re: What will i need to run mid 14's?
    Universal Turbo Sound WHOO WHOO WHISTLE Whisler ALL CAR on eBay.ca (item 290456266962 end time 19-Aug-10 18:55:42 EDT)
    This... you need this now.
    You will only nuke tranny's if you beat on a poorly built one.
  10. #10 Re: What will i need to run mid 14's?
    Jul 2010
    New England
    haha if i get that i will be in the low 9's
  11. #11 Re: What will i need to run mid 14's?
    Jul 2010
    New England
    Also I was looking at the 3800 performence pcm and was wondering if i need a pulley to use it?
  12. #12 Re: What will i need to run mid 14's?
    GT Level Member AmericanRiceEater's Avatar
    New York
    I just finished my 3.4" set up and it's a completely different car. The gain in power and change in feel is night and day. I know everyone says look up the properly modding your 3800 car forum but it's a good idea. It's pretty much listed in order what you should do. I did my CAI --> Headers --> PCM --> Plugs&Stat --> 3.4" MPS. The big gains come late when you install the PCM and pulley.
    Black 2000 GTP Coupe. SSAutoChrome headers, K&N Cold Air Intake, Reptile Tuned PCM, 3.4" ZZP MPS, 104 Autolites & 180 Stat.
    PS3 Online: Zirpola (Dont use mic.)
  13. #13 Re: What will i need to run mid 14's?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    FWIW I ran a 14.3 with a 4.0 pulley and a plog,downpipe and WAI
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  14. #14 Re: What will i need to run mid 14's?
    Jul 2010
    New England
    Also another reason I dont really want headers is i have no clue how to install them and I heard that to get it done at a shop it will run around 500 bucks
  15. #15 Re: What will i need to run mid 14's?
    Apr 2009
    stockton ca
    Headers is a 3 hur job very straight forward pull dog bones pull front mani pull xover
    unbolt down pipe remove rear mani
    pull rear valve cover
    instal rear bolt up very loss
    bolt up xover bolt in front get it all ined up and bolt in tight tighten clams hook up new dp section and dog bones and vroom vroom
  16. #16 Re: What will i need to run mid 14's?
    Jul 2010
    New England
    I know I would screw something up haha
  17. #17 Re: What will i need to run mid 14's?
    New York
    I paid 250 for the installation of my headers, they welded in a new flex pipe and included a cat converter. It took a few hours.
  18. #18 Re: What will i need to run mid 14's?
    Jul 2010
    Minnesota
    I did mine for free with a few swear words and some good old fashioned physical pursuasion
mid, run
