Thread: Engine returns to idle
Results 1 to 7 of 7
  1. #1 Engine returns to idle
    SE Level Member tuchek's Avatar
    Witt, Il.
    I have a 99 gp gt. At any speed the the rpms drop to idle when i let off the accelerator. Any ideas why?
  2. #2 Re: Engine returns to idle
    its supposed to do that.
    its not a manual and doesnt maintain rpm's when you let off. the car is coasting how its supposed to when you let off.
  3. #3 Re: Engine returns to idle
    Apr 2009
    Wausau, Wisconsin
    You drive an auto..
  4. #4 Re: Engine returns to idle
    Apr 2009
    stockton ca
    Its the magic of the all mighty AutoMatical Trans
    Its better for fuel econ and easier on your powertrain aswell embrace it my friend embrace it
  5. #5 Re: Engine returns to idle
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Just to summarize the conversation in the chatbox for anyone that runs into this later.
    The RPM should drop, but not all the way to idle. You can get the effect you're talking about if the splines on the 4th clutch hub are stripped off. You also said you're at 3000 RPM at 70 MPH, which is far too high, and supports the theory that the clutch hub is toast.
    While cruising on the highway, pull the shifter back into 3rd and see if it downshifts. If not, we've found the problem.
    Thanks to Reptile for helping in this diagnosis.
    2001 Buick Regal LS - Almost Stock
  6. #6 Re: Engine returns to idle
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    mine was doing that too and it was a vacuum leak on the LIM.
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  7. #7 Re: Engine returns to idle
    Apr 2009
    stockton ca
    he said at 70mph he was at 3300 or so
    so yea thats a trans issue more then likely 4th is gone BUT at the beginning it was explained that way
  1. Warm engine won't idle.
    By Jaybird in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2010, 04:51 AM
  2. rough idle after engine replacement
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2009, 07:55 PM
  3. rough idle after engine swap
    By almighty in forum Engine
    Last Post: 11-18-2009, 06:25 PM
  4. engine will not idle
    By SCGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2009, 06:00 PM
  5. What did u do with your tax returns.
    By Panther427 in forum Off Topic Discussion
    Last Post: 02-22-2009, 07:41 PM
