Thread: How to install throttlebody heat shield
Results 1 to 7 of 7
  1. #1 How to install throttlebody heat shield
    GXP Level Member ryangtp89's Avatar
    Maine
    I just got my tb hs and new sc snout plug today, so i changed my sc oil in like 2 minutes it was dirty as hell well anyways im not really sure where you are supose to bolt the tb hs up to and what bolts you use. Just alittle lost here. Oh btw i'm getting my 3.4 pulley, dp, al 104s and 180* installed tomorrow!!! Can't wait.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  2. #2 Re: How to install throttlebody heat shield
    Oklahoma
    Moved this over to the tech lounge for assistance.
  3. #3 Re: How to install throttlebody heat shield
    Maine
    K thanks
  4. #4 Re: How to install throttlebody heat shield
    Oklahoma
    Its only one picture, but I have a picture of my Grand Prix tear down in the L67 section that shows my heat shield mounted to the throttle body. Dont know how much help it will be but it may get you started.
  5. #5 Re: How to install throttlebody heat shield
    Maine
    What bolts do you use ?
  6. #6 Re: How to install throttlebody heat shield
    Oklahoma
    You can use the existing bolts/nuts. Its the bottom 2 on the throttle body. However, my mounting tabs on the shield broke, so I had to fab up some new ones, but it still mounts in the same place.
  7. #7 Re: How to install throttlebody heat shield
    Maine
    Ok i installed it, it took like 5 minutes, the bolt to the right was a little pita but i got it, thanks for the help.
  1. Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
    By Quicksilver_GP in forum How To Write-Ups/Tech Tips
    Last Post: 08-28-2013, 09:12 PM
  2. Heat Extractors
    By bula81069 in forum Visual/Body Modifications
    Last Post: 04-04-2008, 08:08 AM
  3. Stereo INSTALL.....need help
    By TMOTA503 in forum Audio, Security & Visual Electronics
    Last Post: 02-28-2008, 11:01 PM
  4. Cam Install Kit- What do I really need?
    By 1998gpgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 01:40 PM
  5. DIY catback install?
    By IndeedSS in forum General Tech Discussion
    Last Post: 02-26-2008, 12:04 AM
