So I have never taken off the door panels of my 4 door,
but I need to take my mirrors off, so they need to come off.
Can someone please post some pics of the procedure, and what
clips are infamous for breaking. THanks!
2 bolts near door pull, and a bunch of plastic clips that break half the time (get a box of new ones you'll need them) they come off pretty easy
archemedes, where is the best place to get those clips?
most parts stores have them in the help section under $5 for a box I think (I buy bulk from one of my distributors no clue what I pay anymore)
In AutoZone at the nuts and bolts section, orange boxes, they're white clips for GM vehicles, $2.99 a pack.
As far as the bolts, they're torx heads and if you look under the inside door pull you'll see two cosmetic plugs. Remove those and you'll have access to the bolts, they're installed at an upwards angle. After that, just start pulling. Be mindful of the plugs for the window switches and courtesy light (you can remove it before hand, your choice) and door handle.
thanks guys!
I will be trying to get them off this week so I can get the damn mirrors off.
Can't you just pull the top plate cover off a bit and then use a combination wrench to get those out without removing the whole door panel? Then disconnect the power wires?
