I managed to create a short at the alternator. A bit of smoke and a pop came from abouts the region of where the alternator wire gets to the starter, and the rest of the electrical system on the car seems fine, so I am relatively certain that the damage is confined to the alternator section of the circuit. I think I blew at least one of the three fusible links.
First, where do the smaller red wires off of the starter go? Second, once a fusible link blows, it is gone for good, correct? On to diagnosing, I ran at it with my multi-meter. The battery is definitely not charging. I am getting very slight voltage at the alternator wire post on the alternator. Shouldn't I be getting something there? Does this allude to both the alternator and the wire being bad, because if the alternator worked it would be creating voltage, and if the wire was good, I would be reading voltage from the battery? Any suggestions on where I can get a replacement alternator wire?
