Thread: Supercharger coupling OR Supercharger belt tensioner?
Results 1 to 20 of 26
  1. #1 Supercharger coupling OR Supercharger belt tensioner?
    dfw, tx
    Started getting a rattling noise coming from the front of the motor and at a quick glance and listen, I thought it was coming from the supercharger belt tensioner. I noticed the noise was only happening at idle and that the tensioner pulley would kinda bounce up and down...
    But once I rev it up a little past idle the noise went away and the tensioner seemed to tighten up and quit bouncing. So I figured I'd need to just replace the whole tensioner and ordered one from RockAuto.
    Well after doing some more research I noticed that the supercharger coupling is notorious for making the same type of noise and only doing it at idle... So now I'm wondering if I really need the tensioner replaced or if I should just replace the coupling?
    Any thoughts??
  2. #2 Re: Supercharger coupling OR Supercharger belt tensioner?
    Donating Users Ibwrong's Avatar
    Oklahoma City
    I'd still say coupler.
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  3. #3 Re: Supercharger coupling OR Supercharger belt tensioner?
    Outer Space
    From my experience... the tensioner... when it goes... it seizes and throws belt.
    02 GTP 13.6 @ 100mph - SOLD
  4. #4 Re: Supercharger coupling OR Supercharger belt tensioner?
    dfw, tx
    Quote Originally Posted by Lawngoose View Post
    Well it doesn't seem as if the pulley itself is bad, just the spring that keeps tension on the belt since the whole assembly bounces up and down while the motor is turning
  5. #5 Re: Supercharger coupling OR Supercharger belt tensioner?
    SE Level Member xsvtank's Avatar
    NJ
    hey i have the same problem as you and i just put a thread up hopefully we will get a answer
    http://www.youtube.com/watch?v=pSsSctYvOoI
  6. #6 Re: Supercharger coupling OR Supercharger belt tensioner?
    dfw, tx
    Quote Originally Posted by xsvtank View Post
    YouTube - Replacing a worn out supercharger coupler on 3.8 GM engines
    Did you get an answer to your question? You said so in your other thread.
    I think I'll start by replacing the coupler since it's only $10 and if that cures the problem, I can send my $60 tensioner back.
  7. #7 Re: Supercharger coupling OR Supercharger belt tensioner?
    do you have the rock tumbling noise? No? not coupler. Did you try seeing if all the pulley's moved freely without noise?
  8. #8 Re: Supercharger coupling OR Supercharger belt tensioner?
    Oklahoma City
    Quote Originally Posted by 99gtxws6 View Post
    I guess ive been out of the game for a while.. where do you get it for $10?
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  9. #9 Re: Supercharger coupling OR Supercharger belt tensioner?
    GT Level Member AmericanRiceEater's Avatar
    New York
    i just got a green coupler and some oil from zzp for like 50. gangsta
  10. #10 Re: Supercharger coupling OR Supercharger belt tensioner?
    Banned - Busted For Scamming
    Feb 2009
    The factory coupler is $10 but who the hell wants that piece of crap?
  11. #11 Re: Supercharger coupling OR Supercharger belt tensioner?
    theres a dorman number for the part lol
  12. #12 Re: Supercharger coupling OR Supercharger belt tensioner?
    dfw, tx
    I guess you could say it's a rocks tumbling noise...only at idle. Just above idle and it goes away.
    And if it's the tensioner, it's not the pulley. I'd think it'd be the actual tensioner itself since that's what I'm noticing is bouncing around until I put a load on it by revving the motor. Pulleys all still spin freely.
    Quote Originally Posted by Ibwrong View Post
    Rockauto has it for $10 plus $11 for shipping lol
  13. #13 Re: Supercharger coupling OR Supercharger belt tensioner?
    GT Level Member hourang's Avatar
    commerce, mi
    if your tensioner is too loose then its bad. on mine i can lift the belt up and move the tensioner with it without much force. also have signs of the belt schredding because of it, black rubber around the s/c pulley. i also have the rock noise, im replacing both the coupler and tensioner. check the tensioner anyway.
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  14. #14 Re: Supercharger coupling OR Supercharger belt tensioner?
    Portland Oregon
    Omg, easiest way to figure out if it's the coupler.... Take the s/c belt off and spin the s/c pulley back and forth. If it feels loose or clunky it's the coupler.
  15. #15 Re: Supercharger coupling OR Supercharger belt tensioner?
    Joliet, IL
    take a long flat head screw driver and put the tip on the snout place handle end on your ear you'll be able to tell where the rattle is coming from....do the same with a longer item on the tensioner....you'll hear it.
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  16. #16 Re: Supercharger coupling OR Supercharger belt tensioner?
    dfw, tx
    I was able to pull the supercharger belt off by hand, is that normal?
    Anyways, I had the belt off and I spun the supercharger pulley back and forth and could hear a faintly similar sound to what i'm hearing when the car is running so I bet it is the coupling.
    Though the tensioner being that loose where I can remove the belt by hand is kinda worrysome, unless it's normal, then I guess I'm just being overly paranoid
  17. #17 Re: Supercharger coupling OR Supercharger belt tensioner?
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    you shouldn't be able to take the belt off by hand..your tensioner is most likely nfg. And you should replace the coupler anyway, its going to have to be done at some point anyway, might as well be when you're already working on the car.
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  18. #18 Re: Supercharger coupling OR Supercharger belt tensioner?
    commerce, mi
    like i said, just like my car, both are bad.
    -Jeff
  19. #19 Re: Supercharger coupling OR Supercharger belt tensioner?
    dfw, tx
    Put a new coupling on today and filled the blower up with oil.
    Fired it up and it's still f-in knockin...LOL
    So I'll replace the tensioner tomorrow and see if that cures it. Oh well...I needed to change my supercharger oil anyways. Damn that stuff stinks...
  20. #20 Re: Supercharger coupling OR Supercharger belt tensioner?
    commerce, mi
    video of noise? remove s/c belt, still make noise?
    -Jeff
  1. How to remove Supercharger Belt?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2010, 03:51 PM
  2. supercharger belt slips
    By neel2008 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2009, 09:31 AM
  3. weird noise from supercharger/belt area
    By bonerjamz03 in forum General Tech Discussion
    Last Post: 07-06-2009, 02:40 AM
  4. Supercharger Belt Came Off!!
    By jjwalton77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-14-2008, 03:34 AM
