Thread: HELP Starter?
Results 1 to 6 of 6
  1. #1 HELP Starter?
    Akron Ohio
    I have a 1997 Grand Prix GTP. 3.8 S/C My car sometimes starts fine then other times I hit the key and the starter engages but does not turn the motor over? It seems like it starts normaly when the cars hot. Sometimes
    Yes the Battery is fine.
  2. #2 Re: HELP Starter?
    HUDSON
    I would check batter cable first. But what you describe sounds like worn brushes in the starter which is 99.9% of the time that goes bad.
  3. #3 Re: HELP Starter?
    Akron Ohio
    Quote Originally Posted by QUICKSILVER462 View Post
    Is there a way to do a rebuild on the starter?
  4. #4 Re: HELP Starter?
    GTX Level Member bronzemist02's Avatar
    Canada
    Indeed there is. How to Rebuild a Starter | eHow.com
    I have rebuilt alternators before, but no starters. Not too hard though.
    02 GT: Silverstar ultras, nighthawk platinum 2157s, ngk plugs, champion wires, 6k hid fogs, stainless magnaflows, cleaned tips, 2 10" subs. Finally painted.
  5. #5 Re: HELP Starter?
    Nov 2008
    Chicago
    x2
    I've revived a bunch of motors using this same method.
    After i had my trans replaced, my car was doing the same thing. Turns out the starter wiring connector was corroded.
    97 GTP Sedan: 3" from the downpipe to the mufflers, no cat, ADR 17's, AGX/Eibach, HAI w/k&n, 6k HID's
  6. #6 Re: HELP Starter?
    Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly! Fugly!
  1. Need help with a starter...
    By kcbuckeye2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-29-2010, 12:14 PM
  2. Replacing Starter on 98 GT
    By johng80 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-26-2010, 06:59 PM
  3. S10 2.2l Starter Motor??
    By SDGTP99 in forum Off Topic Discussion
    Last Post: 12-23-2009, 04:12 PM
  4. Automatic Starter?
    By SuperCharged0nE in forum General Tech Discussion
    Last Post: 11-26-2009, 09:12 PM
