Thread: Need advice on 1970 grand prix sj
Results 1 to 7 of 7
  1. #1 Need advice on 1970 grand prix sj
    Jun 2010
    placerville
    hey everyone, i just recieved a 1970 grand prix from my grandfather who passed away a couple months ago. I dont need the car and i dont want it to just sit around in my garage. i would rather sell it to someone that would take care of it. i dont really know what its worth and was wondering if someone could help me out with that.
    the car is a 1970 grand prix sj, midnight blue with white vinyl top, has 57000 miles, one owner, automatic, interior is in great shape and exterior is flawless. car is 100% original. hasnt been driven since 1996. any advice would be greatly appreciated. thanks a lot
  2. #2 Re: Need advice on 1970 grand prix sj
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    I'll trade you my 97 GTP straight up for it.
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  3. #3 Re: Need advice on 1970 grand prix sj
    Dec 2008
    chicago,illinois
    Post pics
    going low on 20"
  4. #4 Re: Need advice on 1970 grand prix sj
    Nov 2009
    wentzville
    If you are considering starting that engine, if it has really been dormant for 13+ years, I would pull all the plugs and dump liberal amounts of tranny fluid in the cylinders and then crank the engine over by hand after letting it sit a day or so. Do this slowly over several days.
    Carb will have to be pulled and flushed/inspected and probably the fuel tank also.
    Make sure you do not use the starter to crank the engine over at first. Next I would change the oil out with fresh and use an oil pump primer to get oil all through the motor.
    This car was originally equiped with a points type ignition, I would give it a full tune up with points, rotor , cap and condenser.
    I have started engines that have sat this long ( and longer -20+ years!) and this is what really needs to be done to try to limit any damage to the engine.
    Over this much time, the bores and other machined surfaces can rust, the possibility that the rings are rusted to the bores is certainly there.
    PM me if you like.
    1969 Pontiac GTO
  5. #5 Re: Need advice on 1970 grand prix sj
    Jun 2010
    placerville
    thanks for the quick feed back. the car has sat in my grandfathers garage since 96. he use to drive it every so often but since then it hasnt moved. i have some pics of the car i can post but there almost 15 years old. car is exactly the same as it when then though. thanks for the advice on how to fix it up to start it. im probably going to tow it to a shop to have it tuned up and everything. what does a car like this usually sell for?
  6. #6 Re: Need advice on 1970 grand prix sj
    Jun 2010
    placerville
    these are the pics of the grand prix.there from 96.car has been garaged ever since
  7. #7 Re: Need advice on 1970 grand prix sj
    Jun 2010
    placerville
    srry pics didnt load, im gonna try another way. from the information i stated above can someone please let me know what this car might be worth. thanks
  1. Need advice on 1970 grand prix sj
    By carter22 in forum Introductions/Noob Questions
    Last Post: 02-10-2014, 04:43 PM
  2. 2002 Grand Prix Gt issues, need some expert advice
    By gtpx02 in forum General Tech Discussion
    Last Post: 06-10-2009, 11:19 PM
  3. Tune Up Advice, Just bought High Mileage Grand Prix GT
    By anicolay in forum General Tech Discussion
    Last Post: 04-29-2009, 02:57 PM
  4. 1970 Pontiac Rear End
    By sfgreen in forum General Tech Discussion
    Last Post: 04-28-2009, 12:59 AM
  5. Anybody have advice for stock '95 grand pix 16" rims?
    By jjk1000 in forum Tires & Wheels
    Last Post: 09-01-2008, 02:56 AM
