Thread: How do you replace the coolant elbows?
Results 1 to 18 of 18
  1. #1 How do you replace the coolant elbows?
    SE Level Member Mercenary's Avatar
    Sav
    The elbow by the water pump was cracked and leaking a decent amount. So I went and bought some new elbows (Dorman #47065) I removed the damaged one but I can't figure out how to put the new one or which one I should be using. Neither one is an exactly the same as my old one.
    I have my alternator off but I can't figure out how to get the tensioner off and I already snap a sensor trying to get it on. Please help
  2. #2 Re: How do you replace the coolant elbows?
    there are three bolts on the tensioner, two that are easy to spot, and one thats on the back side of it. All three go into the head, are the same length and have 15 MM heads.
    Take those off then it'll come right off.
  3. #3 Re: How do you replace the coolant elbows?
    Sav
    Ok I'll check that out tomorrow, Any ideas on what kind of censor I broke? It's right above the elbow and is T shaped. I'm thinking it's some kind of temperature censor.
  4. #4 Re: How do you replace the coolant elbows?
    Donating Users Ibwrong's Avatar
    Oklahoma City
    Quote Originally Posted by Mercenary View Post
    That not a sensor, thats a vacuum T. Just go to your local auto parts store and get a T with some reducers and vacuum line, should be good to go then.
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  5. #5 Re: How do you replace the coolant elbows?
    Sav
    Quote Originally Posted by Ibwrong View Post
    Is the car drivable with out the vacuum T?
  6. #6 Re: How do you replace the coolant elbows?
    Oklahoma City
    It will try to run, but it will run like ****. Thats a HUGE vacuum leak
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  7. #7 Re: How do you replace the coolant elbows?
    Sav
    ok I've spent almost a hour looking for the three 15mm bolts and didn't have any luck finding them. Could you post a pic please?
  8. #8 Re: How do you replace the coolant elbows?
  9. #9 Re: How do you replace the coolant elbows?
    Sav
    Is that a GT? I have a GTP...
  10. #10 Re: How do you replace the coolant elbows?
    ... Its a GT with a GTP top half of the engine.
    Thats what the 99+ tensioner bracket looks like. What year is your car?
  11. #11 Re: How do you replace the coolant elbows?
    Sav
  12. #12 Re: How do you replace the coolant elbows?
    then it'll have the exact same bracket on it.
    This is right underneath the alternator.
    Right near the power steering reservoir.
  13. #13 Re: How do you replace the coolant elbows?
    Sav
    ok turns out that the power steering bolt was the one I was missing. Damn that was easy, now I just have to fix the vacuum line. Any tips for that?
  14. #14 Re: How do you replace the coolant elbows?
    whats broken?
    I'd suggest just replacing the lines alltogether at this point.
    Easiest way is to take the old stuff into the parts store and find something the same inner diameter. You might need a new plastic T as well, just get a universal one from the self help section.
  15. #15 Re: How do you replace the coolant elbows?
  16. #16 Re: How do you replace the coolant elbows?
    Brewcity, WI
    ^^wow... there was actually something useful on that site... never knew
    Is that gasket crap necessary? I just dipped mine into antifreeze to lube'em up?
    Self-denied SMGPFC member #1
    SEARCH works!
  17. #17 Re: How do you replace the coolant elbows?
    or spit on them.
  18. #18 Re: How do you replace the coolant elbows?
    Jul 2010
    nashville
    Thank you for the info that is posted (also pics) I recently have experienced the same problem
  1. Coolant elbows
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 12-01-2009, 11:58 AM
  2. Coolant Elbows for 2000 GTP
    By nickbuol in forum General Tech Discussion
    Last Post: 07-21-2009, 10:51 PM
  3. Should I and what to replace??
    By torq455 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2009, 08:13 PM
  4. what do i need to replace
    By guy87 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-27-2009, 07:30 PM
  5. Replacing uim and lim 97 gp 3.8 (Coolant Elbows?)
    By Onthebrinc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-13-2008, 05:27 PM
