Thread: :+:+: Pacsetters vs SSAC ? Urgent :+:+:
Results 1 to 8 of 8
  1. #1 :+:+: Pacsetters vs SSAC ? Urgent :+:+:
    GT Level Member AmericanRiceEater's Avatar
    New York
    Hey im well aware that there is a headers and manifolds forums. I have actually posted this same post on the Header and Manifold forum and it hasn't gotten a response for a while, it hasn't been active for a half month. If you decide to move this forum i'll understand but hopefully ill get some info. i need before you do. Thanks.
    Hey i've got some questions for both the Pacesetter and SSAC Headers. If someone takes a few minutes to answer these questions fully id really appreciate the help ! Thanks !
    -When it comes to the pacesetters are they extremely hard to seal ? Or just a little time consuming ? And exactly how intense is the weld job for these?
    -Also as far as the SSAC what would i need to do to fix the slip joints ( is it practical ) ? And what are the cons for the O2 sensor hitting the floor board? (Noob question i know).
    Thanks everyone !
  2. #2 Re: :+:+: Pacsetters vs SSAC ? Urgent :+:+:
    Nov 2009
    Grand haven
    ssac are better IMO, coper rvt on the slip joints (get some band clamps too) and I just got an o2 simulator that way i did not need a o2 ext harness and had no problems with the o2 sensor hitting the floor board(left the screw in plug in the bung).
  3. #3 Re: :+:+: Pacsetters vs SSAC ? Urgent :+:+:
    GTP Level Member
    Pittsburgh
    Preface, i have installed or help install every set of headers on the market and some ones that are not on the market any more
    Pace****ters are a very poor designed header, the doughnut gasket from the front to the crossover never seals good, and then there is always a leak at the y pipe where the rear meets the crossover. you need to weld the Y pipe section
    SSAC are the SLP knockoffs. They are very close to the SLP in design, they fit awesome. The only down side is the downpipe of the SSAC have a ticking problem. You will want that replaced before they are installed. The ZZP triple wall flex pipe is a great replacement V band clamps make the install easy and leak free
    FWIW i have a set of the Orignal SLP's on my car with the ZZP TW flex
    2003 SSEi,
  4. #4 Re: :+:+: Pacsetters vs SSAC ? Urgent :+:+:
    New York
    Awesome great help guys thanks ! Sorry for reposting this but i got the help i needed.
  5. #5 Re: :+:+: Pacsetters vs SSAC ? Urgent :+:+:
    New York
    Hey2003SEI is this what your talking about to replace the original SSAC flex with ?
    ZZ Performance
  6. #6 Re: :+:+: Pacsetters vs SSAC ? Urgent :+:+:
    Nov 2009
    Grand haven
    The flex pipe part of the Header. Gives you a ticking sound I just wrapped mine with header wrap.
  7. #7 Re: :+:+: Pacsetters vs SSAC ? Urgent :+:+:
    Donating Users Ibwrong's Avatar
    Oklahoma City
    Quote Originally Posted by shawngtp View Post
    Wait your running a O2 sim on your front O2 sensor?
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  8. #8 Re: :+:+: Pacsetters vs SSAC ? Urgent :+:+:
    Outer Space
    Quote Originally Posted by Ibwrong View Post
    Good catch.... thats a good way to nuke your engine if so!
    02 GTP 13.6 @ 100mph - SOLD
  1. Urgent read ! Oil oil oil>
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 06-04-2010, 12:43 PM
  2. Urgent help
    By milfadic in forum General Tech Discussion
    Last Post: 05-20-2010, 06:02 PM
  3. urgent is my tranny hooped
    By nascartech in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-27-2010, 11:41 PM
  4. urgent dead car
    By Sunstone in forum General Tech Discussion
    Last Post: 09-07-2008, 12:22 PM
  5. Urgent need of Help
    By Sunstone in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2008, 01:22 PM
