Thread: Dash, HVAC lights not working
Results 1 to 2 of 2
  1. #1 Dash, HVAC lights not working
    SE Level Member christopher8911's Avatar
    North Carolina
    I own a 98 GT. The dash lights and HVAC lights have stopped illuminating. The headlights and tails work. I had this problem months ago and after a week or so it started working properly again. I can switch the lights to the on position with the car off and the headlights work but, still no dash illumination. The overhead lights work with the dimmer switch torned to the right. When I switch the light switch from off to the park light position on, the dimmer will work on my radio momentairley(sp) then it will return to full illumination. There is an aftermarket stereo installed but it has been in the car. I have checked the fuses and they are good. What should I do next?
  2. #2 Re: Dash, HVAC lights not working
    GT Level Member Tommyp2010's Avatar
    Poland, Ohio
    did you ever find a solution to this? I'm having the same problem.
    2006 Mitsubishi Evo IX MR
  1. Head lights and dash lights randomly shut off
    By TheOtherNick in forum General Tech Discussion
    Last Post: 04-01-2020, 05:45 AM
  2. Shifter Lights not working ?
    By yzf125 in forum General Tech Discussion
    Last Post: 11-27-2011, 04:10 PM
  3. dim lights not working, bright lights ok
    By madmex2k in forum General Tech Discussion
    Last Post: 12-07-2009, 11:27 PM
  4. HVAC Cluster Back Lights / CB Radio Install
    By POLECAT2007 in forum Audio, Security & Visual Electronics
    Last Post: 09-21-2009, 09:47 AM
  5. Fog/Driving lights not working
    By trailshredder in forum General Tech Discussion
    Last Post: 03-06-2009, 03:15 AM
