Thread: A/C Works, then Doesn't...?
Results 1 to 15 of 15
  1. #1 A/C Works, then Doesn't...?
    SE Level Member Burls117's Avatar
    Jun 2010
    Grand Rapids, MI
    I have a 98 Grand Prix GT (L36) and the air wasn't cold at the beginning of summer. So i tried a can of super sealant and R-134a(2 cans)...The air was super cold for like 2 weeks. But now the passenger side is blowing pretty cold and the driver side is just luke-warm. My girl friends Grand Prix did the same, but she has climate control, so i figured it was an issue with that. But now mines doing it and I don't know why it's inconsistent; and not staying as cold. How do you know if it's a leak in the compressor or lines, or something else?
  2. #2 Re: A/C Works, then Doesn't...?
    swift current,sask.
    To be honest, your best bet is to take it to a shop and have them look at it for you. You need gauges and other stuff to properly diagnose what is happening.
  3. #3 Re: A/C Works, then Doesn't...?
    Topeka, KS
    Blend Door Actuator's goin bad if one sides way colder. I replaced one of mine this winter. Not fun.
  4. #4 Re: A/C Works, then Doesn't...?
    Jun 2010
    Grand Rapids, MI
    Thanks...Any way to tell where there is a leak; if it's in the compressor or the line? Because today it wasn't cold at all
  5. #5 Re: A/C Works, then Doesn't...?
    swift current,sask.
    You can get a leak dye for the 134a. But if you take it to a real shop they should have an electronic leak detector that they can sniff around with, and gauges to see what it is doing.
  6. #6 Re: A/C Works, then Doesn't...?
    Jun 2010
    Grand Rapids, MI
    Okay, Thanks!
  7. #7 Re: A/C Works, then Doesn't...?
    Charles City, IA
    never put that sealer **** into the system. All it does is ruin everything.
    SMGPFC Two Nipple General
  8. #8 Re: A/C Works, then Doesn't...?
    swift current,sask.
    The only stuff that i would trust would be nu-calgon stuff, but its more for residential than automotive.
  9. #9 Re: A/C Works, then Doesn't...?
    GTP Level Member AjL227's Avatar
    IL
    Buy a set of R134 hot/cold side gauges, and study up on A/C systems for the DIY fix.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  10. #10 Re: A/C Works, then Doesn't...?
    swift current,sask.
    Quote Originally Posted by AjL227 View Post
    It can be but you need a vaccum pump and the disconect fittings for the automotive type fittings and all that other garbage. Refrigerant is about $35.00/lb so you won't be saving much in the long run.
  11. #11 Re: A/C Works, then Doesn't...?
    Charles City, IA
    Quote Originally Posted by whiney View Post
    Untill you start filling other peoples cars.
  12. #12 Re: A/C Works, then Doesn't...?
    Jun 2010
    Grand Rapids, MI
    Thanks for the help guys!
  13. #13 Re: A/C Works, then Doesn't...?
    SE Level Member Marks97GTP's Avatar
    North Carolina
    Mine was doing the same thing, had evac and recharge .. Like new ! $111.67 at Firestone Car Car.
  14. #14 Re: A/C Works, then Doesn't...?
    GTP Level Member SuperSport's Avatar
    Michigan
    It plugged my orifice tube. That was fun to change....my arms are tore up.
    ALWAYS take AC work to a shop! A vac and fill was 60 bucks after I changed my 4 dollar orifice tube.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  15. #15 Re: A/C Works, then Doesn't...?
    Charles City, IA
    exactly.
  1. A/C problem. It works but it doesn't. Yes it's charged
    By TDCRacing in forum General Tech Discussion
    Last Post: 07-27-2010, 04:18 PM
  2. 99 GTP A/C works great, then stops, then works great again
    By stotzbotz in forum General Tech Discussion
    Last Post: 09-27-2009, 02:39 PM
  3. Gas gauge works then doesn't...?
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 10-03-2008, 04:14 AM
  4. It Works!!!
    By 02BlueGT in forum PCM Tuning
    Last Post: 08-31-2008, 01:02 AM
