Thread: front control arm bushing
Results 1 to 20 of 22
  1. #1 front control arm bushing
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    hello all. as we all know, this bushing is "pressed" in.
    was wondering if it HAS to be pressed out, and back in, or if a person would be able to do it themselves with like a dead blow hammer or something??
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  2. #2 Re: front control arm bushing
    GT Level Member gpbastard's Avatar
    Florida
    Quote Originally Posted by Jakegday View Post
    Nobody really replaces the bushings on these cars. chances are the rest of the bushings along with the ball joint are getting worn out as well. It's probably a good time to replace both lower control arms. Rockauto.com has them for about $150.00 a pair plus shipping...
  3. #3 Re: front control arm bushing
    You can get ones with poly bushings and a HD ball joint from the W body store for $270 a pair + shipping IIRC.
    GM bushing is $25 from the dealer I believe if you really want one.
  4. #4 Re: front control arm bushing
    looks fast.... its slow:) beckys2000gt's Avatar
    Nov 2009
    stoystown, pa
    i did the bushing on my gt, and they were like 27 for the front one.......... and if you need the whole controll arm, go to autozone, 125 bucks.
  5. #5 Re: front control arm bushing
    Florida
    matt might know, but i believe you need a special tool to get them in and out...
  6. #6 Re: front control arm bushing
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by gpbastard View Post
    then i guess everyone has alot more F'ing money then me. the other bushing has been replaced, and if a ball joint goes bad, oh well. ill tackle that for $25
    $13 for the bushing from a GM dealership. its steel on steel, by the way. no way ill be able to beat it out with a hammer
  7. #7 Re: front control arm bushing
    its pressed in.
    control arms are cheap and worth your time.
  8. #8 Re: front control arm bushing
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    I might be a bit late on this replay but i replaced mine and yes i had to use a press to get it out! and be carefull, make sure it comes out straight or u ruin the table/control arm and then have to buy a new one lol. the bushing was 22$ from a local autoparts store but ur better off just buying a new table/control arm it comes with the ball joint and both bushing for 125$ and no hastle of pressing out the old 1 and pressing back in the new one! was a ***** for me!
  9. #9 Re: front control arm bushing
    Nov 2008
    Fremont Nebraska
    how am i better off spending $125, to only replace about $50 worth of parts?
    does the arm itself just deteriorate over time or something?
  10. #10 Re: front control arm bushing
    Florida
    you know the old saying of pay now or pay later certainly applies here. like i said before if a couple of bushings are bad there's a good chance the rest of the control arm isn't far behind. plus, you probably don't want to start mixing new and old parts together like that. it might affect handling...
  11. #11 Re: front control arm bushing
    Nov 2008
    Fremont Nebraska
    weather i replace just the bushing, or the entire arm, the car should technically get an alignment afterwards either way. which would take care of any handling difference. and the point im trying to make (or question) is that control arms dont go bad. its a solid chunk of steel. unless you damage it (which would damage a new one too) theres only about $50 worth of parts on it that can go bad
  12. #12 Re: front control arm bushing
    Florida
    what i meant by the "control arm" is the parts attached to it. bushings and ball joint. yes an alignment afterwords is a good idea. with some old parts still attached the alignment might not hold for very long. you're not saving all that much by putting new parts on an old arm. plus, from what other's have said the individual parts are a major pain to put in. it's your call if you want to hassle with putting the bushings in. it's much easier to put the whole arm in in one fell swoop....
  13. #13 Re: front control arm bushing
    GT Level Member MBruneaux's Avatar
    Canterbury, CT
    If you are willing to do the work and save the money, I got mine out with just a chisel and hammer and installed with a hammer. Just bang them in evenly and against a block of wood or something. I replaced the ball joints and tie rods while I was at it. It's work.
    2001 Grand Prix GTP - Daily Driver12" front brake upgrade ('05 Monte), Raptor tune, Open cone, Front and rear strut tower braces, SS brake hoses, BMR trailing arms, ZZP 3" catted downpipe, Dorman front sway bar, GMPP rear sway bar, solid trans and engine mount, flipped dog bones and Borla exhaust.
  14. #14 Re: front control arm bushing
    With the control arm you get the ball joint as well... Something you should probably replace anyways.
    Price out that bushing and new ball joints then come back and say its not worth it considering how much easier the job will be.
  15. #15 Re: front control arm bushing
    Nov 2008
    Fremont Nebraska
    ok....? its not worth it.....
    theres only 4 nuts/bolts holding on the control arm. from the moment i slid the jack stands under the car, i had the arm off in 30 minutes. and this was the first time ive ever done this to this car. its really not that hard to remove/install.
    the ball joint ($25 part) MIGHT take 2 minutes to remove, depending on how nice of a drill you have (mines fairly nice). MAYBE 5 minutes to install and tighten the nuts/bolts on the new one
    and the bushings are $13 a piece at the gm dealership. $20 to have 1 removed and reinstalled.
    i could care less about how much "easier" a whole new control arm would make the job.. i have more time then money
  16. #16 Re: front control arm bushing
    Then by all means...
  17. #17 Re: front control arm bushing
    the point i was trying to make was that my experiance it took me 30 mins to get the arm off and almost an hour to press the bushing out it wouldnt freaking come out lol and when i did i bent part of the control arm around where the bushing sits. 1 month later the bushing poped out and i had to replace the whole control arm.
  18. #18 Re: front control arm bushing
    SE Level Member trenaro's Avatar
    Feb 2009
    KC
    Two minutes to remove the ball joint? You should own a shop. Be a bazillionaire
  19. #19 Re: front control arm bushing
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    four months 'til revival of this thread? you should run a forum. be a gizenius.
    97 GT - slow, rusty
    93 CTD - more slow, less rust
  20. #20 Re: front control arm bushing
    Charles City, IA
    lol 2 mins to do a ball joint. I bet you cant get the wheel off the ground in that time.
    SMGPFC Two Nipple General
  1. Value cover Screw bushing things
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2010, 12:16 PM
  2. Upper Control Arm Bushing
    Last Post: 07-21-2009, 11:06 PM
  3. Control Arm Bushing
    By VGPGT in forum Brakes/Suspension/Chassis
    Last Post: 06-11-2009, 03:56 PM
  4. Bushing
    By JCG's-GTP in forum Brakes/Suspension/Chassis
    Last Post: 02-09-2009, 02:31 AM
  5. Front Control Arm Bushings
    By 2001camaroB4C in forum Brakes/Suspension/Chassis
    Last Post: 11-23-2008, 01:38 PM
