Thread: twelve inch brake upgrade
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
  1. #1 twelve inch brake upgrade
    SE Level Member Jeckel's Avatar
    Feb 2010
    Nampa, ID
    I did search, but was not able to find a definitive answer. According to rock auto, in order to do the 12 inch brake upgrade, I need brackets from one of the following:
    BUICK LESABRE CUSTOM (2000 - 2004)
    BUICK LESABRE LIMITED (2000 - 2004)
    BUICK PARK AVENUE (1997 - 2004)
    BUICK PARK AVENUE ULTRA (1997 - 2004)
    BUICK RIVIERA (1997 - 1999)
    CADILLAC DEVILLE (1997 - 2005)
    CADILLAC DEVILLE CONCOURS (1997 - 1999)
    CADILLAC DEVILLE DELEGANCE 1997
    CADILLAC DEVILLE DHS (2001 - 2004)
    CADILLAC DEVILLE DTS (2001 - 2005)
    CADILLAC ELDORADO (1997 - 2000)
    CADILLAC ELDORADO ESC (2001 - 2002)
    CADILLAC ELDORADO ETC (1998 - 2002)
    CADILLAC ELDORADO TOURING 1997
    CADILLAC SEVILLE (1999 - 2000)
    CADILLAC SEVILLE SLS (1997 - 2004)
    CADILLAC SEVILLE STS (1997 - 2003)
    CHEVROLET IMPALA (2000 - 2005)
    CHEVROLET IMPALA LS (2000 - 2005)
    CHEVROLET IMPALA SS (2004 - 2005)
    CHEVROLET MONTE CARLO LS (2000 - 2004)
    CHEVROLET MONTE CARLO SS (2000 - 2004)
    OLDSMOBILE AURORA (1997 - 2003)
    OLDSMOBILE INTRIGUE 1998
    PONTIAC BONNEVILLE (2000 - 2003)
    PONTIAC GRAND PRIX GT 2004
    PONTIAC GRAND PRIX GTP 2004
    I was able to find the brackets from a 97 park avenue at the local pick a part for 5 bucks each. My question is this, should I get rotors from one of those cars as well? or what rotors do I need to get?
  2. #2 Re: twelve inch brake upgrade
  3. #3 Re: twelve inch brake upgrade
    Feb 2010
    Nampa, ID
    you need the rotors from one of those cars as well.
    According to rockauto, the 97 park avanue uses the same rotors as the 97-03 gtp and the 04-05 impala ss... so you see my confusion?
  4. #4 Re: twelve inch brake upgrade
    GTX Level Member Juanmiguel's Avatar
    Mexico
    What about the Fbody brakes? I was also looking up which years Fbody fit the GP. Will any 93-02 Fbody (trans am / camaro) brakes will work?
  5. #5 Re: twelve inch brake upgrade
  6. #6 Re: twelve inch brake upgrade
    Feb 2010
    Nampa, ID
    I have the brackets rockauto said i needed. I am just confused by the rockauto site saying the 03 monte carlo ss uses the same rotors as the 97-03 gtp. Here is the list they give:
    BUICK CENTURY CUSTOM (2004 - 2005)
    BUICK CENTURY LIMITED (2004 - 2005)
    BUICK CENTURY SPECIAL EDITION 2005
    BUICK REGAL (1999 - 2000)
    BUICK REGAL GS (1997 - 2004)
    BUICK REGAL LS (1997 - 2004)
    CHEVROLET MONTE CARLO LS (2000 - 2005)
    CHEVROLET MONTE CARLO LT 2005
    CHEVROLET MONTE CARLO SS (2000 - 2005)
    OLDSMOBILE ALERO (1999 - 2004)
    OLDSMOBILE INTRIGUE (1998 - 2002)
    PONTIAC GRAND AM (1999 - 2004)
    PONTIAC GRAND AM GT 2005
    PONTIAC GRAND AM GT1 2005
    PONTIAC GRAND AM SE 2005
    PONTIAC GRAND PRIX (1999 - 2002)
    PONTIAC GRAND PRIX GT (1997 - 2003)
    PONTIAC GRAND PRIX GTP (1997 - 2003)
    PONTIAC GRAND PRIX SE (1997 - 2003)
  7. #7 Re: twelve inch brake upgrade
    Jul 2008
    sumter,south carolina
    you need whatever brackets use the 11.9" rotors.
    fixed.
    02 GTP with mods 05 GP for DD
  8. #8 Re: twelve inch brake upgrade
    fixed.
    actually matt corrected me on this a while ago. i already had this conversation.
  9. #9 Re: twelve inch brake upgrade
    Banned - Busted For Scamming
    Feb 2009
    Just get them for an 05 monte carlo.
    For the f body brakes, any 98-02 camaro, firebird
  10. #10 Re: twelve inch brake upgrade
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    when i did my 12" upgrade i got mine of a 2000 impala brakes and rotors pads are the same though
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  11. #11 Re: twelve inch brake upgrade
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    this will fit with stock mags? but if you were getting bigger brakes wouldnt you need new calipers too?
  12. #12 Re: twelve inch brake upgrade
    Quote Originally Posted by RyanL View Post
    yes and no.
  13. #13 Re: twelve inch brake upgrade
    SE Level Member Slueth66's Avatar
    Nov 2008
    Iowa
    anyone know if these rims are compatible. im guessing they are.
    2005 Pontiac Grand Prix 16" Factory Original OEM Wheel Rim 6587
  14. #14 Re: twelve inch brake upgrade
    Donating Users kfish's Avatar
    Ohio
    stock 16" wheels will be ok with the 12" upgrade. i just did mine this weekend and they fit fine under my abs wheels.
  15. #15 Re: twelve inch brake upgrade
    GTP Level Member SuperSport's Avatar
    Michigan
    Quote Originally Posted by kfish View Post
    I wonder if the Twisted Star 17" Comp G wheels would work with the 12 inch upgrade...
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  16. #16 Re: twelve inch brake upgrade
    Ohio
    well...if 16s work...why wouldnt 17s?
  17. #17 Re: twelve inch brake upgrade
    GT Level Member AdamBall's Avatar
    Wausau, WI
    So you need the FBody rotors calipers and pads for the 12" upgrade to work properly? Is there anything else that you guys would recommend doing after upgrading to these?
  18. #18 Re: twelve inch brake upgrade
    so what is the average cost for you guys doing this 12'' brake upgrade? and did u guys also modify the rear brakes? or does the parking brake screw things up to do so?
  19. #19 Re: twelve inch brake upgrade
  20. #20 Re: twelve inch brake upgrade
    Wausau, WI
    How did you do your upgrade bio?
  1. brake parts to get for brake upgrade??
    By colindunn in forum Brakes/Suspension/Chassis
    Last Post: 01-03-2011, 08:59 PM
  2. Brake upgrade
    By rocket69GTP in forum Brakes/Suspension/Chassis
    Last Post: 04-17-2010, 12:35 PM
  3. what do i need to upgrade to 12 inch rotors?
    By 2000GTP in forum Brakes/Suspension/Chassis
    Last Post: 02-11-2009, 06:00 PM
  4. 05 brake upgrade?????
    By duane9586 in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2008, 02:47 PM
