Thread: LIM gasket!
Results 1 to 20 of 25
  1. #1 LIM gasket!
    SE Level Member 98daytona's Avatar
    Boston
    I have been leaking externally for awhile and it seems the time has come to take this job upon myself. I have no questions about the job itself just wondering what else I should do while I have everything broken down. It is a 1998 Gtp with about 120k (no mods atm). I am not currently getting any "ticks" from the valve train, but while I'm in there would it be worthwhile to change lifters, springs, etc? Basically should I:
    a) Ain't broke, don't fix it
    b) Replace all wearable parts that are accessed while top end is open.
    Planned mods are:
    FWI
    Pcm
    3.5 (maybe 3.4) pulley
    Headers
    If that makes any difference in your suggestions.
    Thanks!
  2. #2 Re: LIM gasket!
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Only thing i would say on this is what ever you do remember to get the replacement supercharger gasket and the yellow o ring and some rtv for the side gaskets.
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  3. #3 Re: LIM gasket!
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    x2 also you might want to port your supercharger while its off just dont go overboard and if you do lifters replace with ls7 lifter it is a oe replacement comp cams lifters suck DO NOT BUY THEM THEY WILL BREAK there is a know defect with them
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  4. #4 Re: LIM gasket!
    HUDSON
    If it aint beroke, don't fix it!!!!!
    And don't do the pulley unless you open the top piston ring gaps at least .015.
  5. #5 Re: LIM gasket!
    Donating Users Ibwrong's Avatar
    Oklahoma City
    Also.... Get the 04+ LIM Gasket!!
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  6. #6 Re: LIM gasket!
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    Quote Originally Posted by Ibwrong View Post
    this.
    it's denoted as "second design" in some companies' catalogs
  7. #7 Re: LIM gasket!
    Quote Originally Posted by QUICKSILVER462 View Post
    what? why? this is such a random off the wall statement it's not even funny. you know how many people went all the way down to sub 3.0 pulleys without opening up the ring gap? a metric **** ton.
    yes, the gap is too tight from the factory, but that doesn't mean you need to open it up in order to run more boost. what you just said is completely and 100% false information.
  8. #8 Re: LIM gasket!
    GTP Level Member SuperSport's Avatar
    Michigan
    Yes and no.
    Yes, get the aluminum gaskets, but no not 04. 04 still used plastic. 05 started aluminum.
    Splitting hairs, but they know what youre talking about at the dealer when you say aluminum LIM gaskets.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  9. #9 Re: LIM gasket!
    Michigan
    part number for the aluminum, anyone?
    i refuse to go to the dealer unless it's free recall work.
  10. #10 Re: LIM gasket!
    Boston
    Thanks so much for the info guys I actually am switching out the S/C coupler while its off as well, though it seems the sound eminates more from the tensioner. I am just chaulkin that up to the play in the S/C pulley. And thanks Nascartech, that would have been the brand i would have went with if I decided to do lifters.
  11. #11 Re: LIM gasket!
    ya just stick with a oe replacement
    Quote Originally Posted by 98daytona View Post
    sold 97 GTP stock
  12. #12 Re: LIM gasket!
    HUDSON
    It's like trying to help a trapped animal, even though your trying to help it, it cannot understand that what you are doing is trying to help it and it keeps trying to fight you off and away.
  13. #13 Re: LIM gasket!
    lol
    sold 97 GTP stock
  14. #14 Re: LIM gasket!
    Jul 2010
    South
    How much it cost to replace LIM Gaskets? I wonder if my mech will know what I'm talking about, and what kind of universal coolant is good to use in GPRix?
  15. #15 Re: LIM gasket!
    i guessing alot and green is good to use in these cars for coolant
  16. #16 Re: LIM gasket!
    Charles City, IA
    Probably be around $400-600.
    SMGPFC Two Nipple General
  17. #17 Re: LIM gasket!
    Jul 2010
    South
    just regular coolant? thx
  18. #18 Re: LIM gasket!
    Jul 2010
    South
    so is LIM the short term word or it means what..?? so when I talk to my mech, just tell him to replace my LIM Gaskets?? Thx Okay so LIM must stand for Lower Intake Manifold, right, just talk to my mech and he said what, he didn't know, so is that right? Lower Intake Manifold??
  19. #19 Re: LIM gasket!
    Quote Originally Posted by mojodare View Post
    yea green coolant is normal coolant just like Dexcool, but people say dex is bad becuse it will do stuff to the motor over time, so thats why i switched to green. It cheap, like 8 bucks a jug a napa and it works great.
  20. #20 Re: LIM gasket!
    Jul 2010
    South
    so is this LIM stands for Lower Intake Manifold?? don't bash please I'm a female, but I know quite a bit about cars.
  1. Oil Pan Gasket
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 12-31-2011, 07:07 PM
  2. Gasket Help??
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-21-2009, 02:21 PM
  3. Lim gasket
    By cardiffGIANT98gtp in forum Introductions/Noob Questions
    Last Post: 09-03-2009, 11:21 PM
  4. Oil Pan Gasket
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2009, 10:03 PM
  5. Gasket Kit
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2009, 01:09 PM
