Thread: missing anything... maintenance related... kinda long
Results 1 to 14 of 14
  1. #1 missing anything... maintenance related... kinda long
    Brewcity, WI
    So I have a few days of vacation coming up (to broke to go anywhere nice), and figured I'd tackle the LIM gasket issue. I am not currently experiencing problems with it, just going to do it before hand. I also need to do some routine maintenance, along with it. Just checking to see of there is anything I'm missing or if someone else can think of something.....
    Car has 122K
    parts list consists of
    1. New plenium w/gasket
    2. Valve cover gaskets
    3. Plugs and wires
    4. Fuel filter/clean air filter
    5. PCV valve
    6. Metal LIM gaskets
    7. New thermostat/gasket/rad cap/hoses (if need be)
    8. Tranny filter & fluid (dexron VI)
    9. Throttle body gasket (incase)
    10. Upper and lower plastic elbows (always break)
    11. Radiator clean/replace dexcool
    12. Oil afterwards
    13. Front 02 sensor
    14. Beer, to keep me occupied
    15. ?????
    Any help is apperciated, as sometimes I have a tendency to overlook the obvious.
    Self-denied SMGPFC member #1
    SEARCH works!
  2. #2 Re: missing anything... maintenance related... kinda long
    you forgot about 'a friend to help you drink the beer'.
  3. #3 Re: missing anything... maintenance related... kinda long
    Donating Users Warbeaver's Avatar
    St. Louis
    seafoam before the oil and plugs
  4. #4 Re: missing anything... maintenance related... kinda long
    Brewcity, WI
    , bring your own. Actually doing this at my dads house (they'll be on vacation), and its right up the road from my "local" watering hole, while growing up!!
    Thing that sucks is I just changed the oil about 1500 miles ago.... damn synthetic, Thanks.
    Think its ok to use regular oil whilst the first 100 miles after assembly? Always heard that you "can't" run anything but synthetic once its used. Seeing how I switched at 3K miles, its been in there a long time.
    SEARCH works!
  5. #5 Re: missing anything... maintenance related... kinda long
    youre a brave man to tackle all of that at the same time. seriously, if you need any help i can stop by and work with you on it. i kind of miss working on my car.
  6. #6 Re: missing anything... maintenance related... kinda long
    Charles City, IA
    You will be fine running reg oil.
    SMGPFC Two Nipple General
  7. #7 Re: missing anything... maintenance related... kinda long
    Brewcity, WI
    I actually took off for 12 days... mostly for a mini vacation away from work, but figured I could do this and stay busy. Otherwise I'll just sit around and drink, plus my car has plenty of work to keep you busy . You any good at welding and painting?
    01GTP=thanks
    SEARCH works!
  8. #8 Re: missing anything... maintenance related... kinda long
    St. Louis
    ah, a mini-vacation to mod the car...thats awsome dude
  9. #9 Re: missing anything... maintenance related... kinda long
    CT
    ZZ Performance
    Just a little extra umphh. Why not upgrade to this while your tearing the top apart.
  10. #10 Re: missing anything... maintenance related... kinda long
    Quote Originally Posted by Pepino View Post
    01GTP=thanks
    i can paint with a rattle can decently, but i cant weld. my younger brother does my welding for me.
  11. #11 Re: missing anything... maintenance related... kinda long
    Brewcity, WI
    Quote Originally Posted by dagger View Post
    ZZ Performance
    Your linkey no workey..... unless its the HV3, I'm not putting it in. Would love to just top swap it, but these "maintence" items are getting to be pricey as it is.
    Nick, I'm hoping to get my spoiler mounted by the june meet, and I know that the mounting holes don't match-up. If I'm correct, need to add 2 holes and fill 2 holes.(adding daytona spoiler to GT trunklid)
    SEARCH works!
  12. #12 Re: missing anything... maintenance related... kinda long
    Donating Users
    South Deerfield, MA
    Unfortunately, it's fill 6 and add 3. That's why I got the whole trunk with mine. Didn't want to mess with all that.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  13. #13 Re: missing anything... maintenance related... kinda long
    You can pick a HV3 up on the cheap used.
    Only other things that wear (on the top end) are the pushrods so inspect those, the lifters, and the valve springs.
  14. #14 Re: missing anything... maintenance related... kinda long
    Brewcity, WI
    Quote Originally Posted by Silver GTP View Post
    dammit, that sucks. Guess I will be searching junk yards, but I'm not going to be able to find a SE trunk lid in galaxy silver though
    done
    and besides fluids & spark plugs... parts ordered
    SEARCH works!
  1. Replies: 16
    Last Post: 04-22-2010, 04:50 PM
  2. Car maintenance
    By ReaperRob in forum General Tech Discussion
    Last Post: 02-05-2010, 02:01 AM
  3. non gp related question
    Last Post: 05-20-2009, 07:15 PM
  4. Genral maintenance on my 98 GTP?
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2008, 04:56 PM
  5. Kinda Long..But I need help
    By TJs97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-26-2008, 05:17 PM
