Thread: Important ? about gauges???
Results 1 to 10 of 10
  1. #1 Important ? about gauges???
    GTX Level Member nikkigpgt00's Avatar
    MI
    Does removing the gauge cluster from the car mess up the alignment of the needles and where they need to be???
    I am going to do my gauges here shortly as soon as I get the bezel overlay. I want to do this without messing up anything with the needles. I am putting white face gauges that do not require removing the needles. I just need to know if I should do this without taking the cluster out. Id like to, would be much easier but bottom line is not messing with the needles so they continue to work properly!
  2. #2 Re: Important ? about gauges???
    Donating Users Warbeaver's Avatar
    St. Louis
    i would just make a rough drawing, showing where your needles should be after looking at them.
    you might have to take the needles off. you just take a fork and get it under the needle and pry upwards. doesnt take much. just make sure you don't move teh spindles that the needles are on. When you get everything back together, based off your drawing and your knowledge, you should know where the needles should be. you can take them off and adjust if they seem off. this is when it's good to have an aeroforce gauge
  3. #3 Re: Important ? about gauges???
    Jul 2008
    Tampa, FL
    yeah, just use some common sense, and you should be fine
  4. #4 Re: Important ? about gauges???
    Nov 2009
    Grand haven
    Nikki i just did mine a week ago. You can slide the over lay on just make sure all the needles are pointing up. Just wondering what ones you bought?
  5. #5 Re: Important ? about gauges???
    Largo, Florida, United States
    hmm i should do red overlays
    GTO style
  6. #6 Re: Important ? about gauges???
    Windsor (ON) Canada
    I took pictures of the gauge needles when I did mine and put them back in the same spot. I found it a little tricky getting them on without taking off the needles, but was successful.
  7. #7 Re: Important ? about gauges???
    MI
    Awesome! Now Im just debating putting them on with or without the overlay? The ones I got are white and go over each spot on the gauge cluster. Opinions???
  8. #8 Re: Important ? about gauges???
    Windsor (ON) Canada
    Are they individual inlays (Tac, RPM, Fuel, Temp), or just one big one covering everything??
  9. #9 Re: Important ? about gauges???
    MI
    They are individual...
  10. #10 Re: Important ? about gauges???
    Windsor (ON) Canada
    ^n/m then, mine was one big one.
  1. Important: ZZP Retainer Issues
    By BillBoost37 in forum General Tech Discussion
    Last Post: 04-04-2012, 10:29 AM
  2. today was an extremely important day because...
    By hondo in forum Off Topic Discussion
    Last Post: 02-10-2010, 12:10 PM
  3. IMPORTANT---Need quick help!
    By nikkigpgt00 in forum Visual/Body Modifications
    Last Post: 01-14-2010, 12:53 PM
  4. Important information about your tires...
    By Keet04GTP in forum Off Topic Discussion
    Last Post: 08-20-2008, 08:56 PM
  5. Few Important Questions
    By wrfdff4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-31-2008, 08:03 PM
