Thread: Mustang wheels on a grandprix??
Results 1 to 20 of 36
  1. #1 Mustang wheels on a grandprix??
    TDCRacing
    Guest
    OK guys I see all the time where ppl are saying that they put mustang wheels on a gp....i have a mustang drag car and just wondering what was up with that? Do they just mean mustang style wheels with a gm bolt pattern?...like the bullets?
    There not the same bolt pattern correct?
  2. #2 Re: Mustang wheels on a grandprix??
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    I believe that the mustang wheels are 114.3x5 and the gp wheels are 115x5, they are different but they will fit. Some people say it is fine to run the 114.3's and some say it will break your studs because of the added stress.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  3. #3 Re: Mustang wheels on a grandprix??
    TDCRacing
    Guest
    Quote Originally Posted by Andrew_99GTP View Post
    You are correct about the bolt pattern on the mustangs....hmmm i got a set of chrome 17'' cobra r's that would look real nice on there lol...
    So that means that all corvette wheels are interchangable with mustang wheels?...wouldnt of thought that...
    anybody else have these on there car and would like to input???
  4. #4 Re: Mustang wheels on a grandprix??
    Oklahoma
    Im kinda thinking out loud here so dont jump on me if this is something way out of line. But with the bolt patterns so close, yet different, could not one take a 64th over drill bit to the mustang wheels to open them up a touch and relieve some of that stress?
  5. #5 Re: Mustang wheels on a grandprix??
    GTX Level Member LowlyfeGTP's Avatar
    Janesville, WI
    Quote Originally Posted by TDCRacing View Post
    Don't think that LOL. Mustang wheels are 5 x 114.3 (close enough to GPs) and most 94+ Mustang wheels will work. Wouldn't go wider than 9" and make sure offset is ok. Also not bad to know center bore of wheels you want to use in case hubcentric rings are necessary. Been debated forever about the stress, but many have run 5 x 114.3 for years with no issue (myself since 1999).
    Corvette wheels are 5 x 4.75 or 5 x 120.7 bolt pattern. They are not interchangeable with Mustang wheels.
    Jason Klingaman
    LOWLYFE
    99 GTP Silvermist Coupe
    360 vid
  6. #6 Re: Mustang wheels on a grandprix??
    TDCRacing
    Guest
    Quote Originally Posted by LowlyfeGTP View Post
    ok but corvette and trans am ect wheels are interchangable with gp's correct??...
  7. #7 Re: Mustang wheels on a grandprix??
    TDCRacing
    Guest
    Yea that is a possibility.....Thanks for all of ya'll's input...The backspacing is stock on the 17x9 cobra r's that i have....wich is 5.5'' for all 87+ years
  8. #8 Re: Mustang wheels on a grandprix??
    Janesville, WI
    No GPs are 5 x 115 and corvettes, camaro, etc. 5 x 120.7. Less than a millimeter ok, but almost 6 is not. That's 1/4" off.
    Jason Klingaman
    LOWLYFE
    360 vid
  9. #9 Re: Mustang wheels on a grandprix??
    TDCRacing
    Guest
    ok i see...kinda...i guess i was just assuming that being it was a pontiac trans am and that some of the wheels that the trans am's have on them (the polished aluminum ones) look just like the ones that i have,made me think that lol
  10. #10 Re: Mustang wheels on a grandprix??
    Janesville, WI
    Like I said most 94+ wheels will fit. 93 and below will not. Backspacing and offset won't always place the wheel in the same spot as Mustang wheels have varied from 6-9" wide. Also alot of the pre-94 wheels were 6" wide and many 4 lug not 5 lug.
    Jason Klingaman
    LOWLYFE
    360 vid
  11. #11 Re: Mustang wheels on a grandprix??
    TDCRacing
    Guest
    right all the 93 on down were 4 lug unless the 5 lug conversion was done to them...wich then gave them the 94+ bolt pattern
  12. #12 Re: Mustang wheels on a grandprix??
    I live here. UR LOSN's Avatar
    Rockford, IL
    nice work Jason!
  13. #13 Re: Mustang wheels on a grandprix??
    Barksdale AFB, LA
    I've seen 5x114.3 break studs before on w-bodies and wouldn't recommend running them. Even with concentric rings. Stick with 5x115.
    2009 Subaru Impreza WRX STI
  14. #14 Re: Mustang wheels on a grandprix??
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Quote Originally Posted by Sabrewings View Post
    I know this is an old thread, but how many have broken because of this? Studs can break with the wheels from the factory, as well, if the conditions are right for it. I'm not slamming, just posing a question is all.
  15. #15 Re: Mustang wheels on a grandprix??
    CT
    Only one that came stock was the cobra edition.
  16. #16 Re: Mustang wheels on a grandprix??
    Quote Originally Posted by SnowDrift View Post
    just about no one. there are a plethora of people running the 5x114.3 bolt pattern with no issues.
  17. #17 Re: Mustang wheels on a grandprix??
    Donating Users ROTTMAN's Avatar
    Feb 2009
    canada
    Sure you have.
  18. #18 Re: Mustang wheels on a grandprix??
    Quote Originally Posted by ROTTMAN View Post
    Sure you have.
    Again.
  19. #19 Re: Mustang wheels on a grandprix??
    GT Level Member SlowRR's Avatar
    Brookfield, IL
    ok i got they dont break studs but what about the vibration issuse, people say over 60 you feel a vibration and even a guy on here said he felt a vibration at 40. i want to put on some bullits but just spent a ton of money past few months getting rid vibration caused by the shafts and motor mounts
  20. #20 Re: Mustang wheels on a grandprix??
    Donating Users
    Plainfield, IL
    ive run 3 sets of 114.3 wheels on my gp and ive never gotten any vibrations just get them balanced real good...im currently running 03 cobras without hubcentric rings and i drive around 80-85 on the highway never a vibration....smooth as butter
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  1. Blew Away A New Mustang GT 5-Speed
    By jdbaringer in forum Track Sessions and Kills
    Last Post: 06-11-2008, 03:20 PM
  2. Mustang Bullits
    By Wadeb79 in forum Tires & Wheels
    Last Post: 04-03-2008, 05:56 PM
  3. Mustang Bullets...dang!!!
    By UR LOSN in forum Tires & Wheels
    Last Post: 04-01-2008, 06:02 AM
  4. Mustang Owner about to buy a GP
    By Nebraska03gt in forum Introductions/Noob Questions
    Last Post: 01-26-2008, 11:24 AM
  5. mustang bullits on 04+?
    By s1795so2 in forum Tires & Wheels
    Last Post: 01-13-2008, 11:55 AM
