Thread: removing the Grand Prix tags
Results 1 to 4 of 4
  1. #1 removing the Grand Prix tags
    Canada
    I have to do some body work and need to remove the Grand Prix tag off the trunk of my 00 gt what is the best way to do this.
    Thanks
  2. #2 Re: removing the Grand Prix tags
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    Use some fishing line to get behind the badge and work it back and forth. That will cut through the adhesive. After you get that off, use some goo gone or a similar product to remove any remaining adhesive. Then wash it off and give it a coat of wax and you should be good.
  3. #3 Re: removing the Grand Prix tags
    GT Level Member lilbear6889's Avatar
    ^^^ thats exactly what i did worked great!
  4. #4 Re: removing the Grand Prix tags
    Windsor (ON) Canada
    Same here...
    Put some goo gone on the adhesive part of the badge while its still on the car, let it set for 5 min (makes it a little easier), then go at it with the fishing line, I used dental floss.
  1. Grand prix GT side skirts on 97 Grand Prix SE
    By Carnes97SE in forum How To Write-Ups/Tech Tips
    Last Post: 11-17-2013, 05:17 PM
  2. Removing drivers seat in grand prix gtp with no battery
    By mikeh in forum General Tech Discussion
    Last Post: 12-08-2009, 06:33 PM
  3. Removing 99 Grand Prix GTP Front Bumper
    By TheNewGuy in forum Visual/Body Modifications
    Last Post: 03-29-2009, 02:52 AM
  4. I.D. Tags ??
    By Roger B in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 03-21-2009, 03:36 PM
