Thread: 20 Mimute Wheel Bearing......HA!
Results 1 to 13 of 13
  1. #1 20 Mimute Wheel Bearing......HA!
    GT Level Member Lvgrandprix2003's Avatar
    Cincinnati
    Well what I thought was going to take 20 minutes to change, took 2 hours and a lot of cutting with a torche! Had to replace the CV axel too, since the heat boiled out the grease and the sledge destroyed the end of it. I have done a multitude of these and this one has been the worst!
  2. #2 Re: 20 Mimute Wheel Bearing......HA!
    GTX Level Member cerick08GP's Avatar
    Omg…It looks like you had to call in Mr. T on that one. “I pity the wheel bearing that messes with me!”
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: 20 Mimute Wheel Bearing......HA!
    Windsor (ON) Canada
    What a Beauty!!!!!!!!!
  4. #4 Re: 20 Mimute Wheel Bearing......HA!
    Cincinnati
    Quote Originally Posted by Colossus View Post
    Did you get a chance to replace your squeeky wheel bearing?
  5. #5 Re: 20 Mimute Wheel Bearing......HA!
    Outer Space
    Chuck Norris was called in?
    02 GTP 13.6 @ 100mph - SOLD
  6. #6 Re: 20 Mimute Wheel Bearing......HA!
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    Chuck Norris could have had that thing off with is pinky toe!
    98' GTP, 18's, BMR Adjustable Forward & Rear Lateral Arms, BMR Tubular Trailing Arms, Intense PCM, CAI, drilled rotors, 5% Tint all around
  7. #7 Re: 20 Mimute Wheel Bearing......HA!
    Charles City, IA
    Why did you have to cut it?
    SMGPFC Two Nipple General
  8. #8 Re: 20 Mimute Wheel Bearing......HA!
    Cincinnati
    CV Axel was siezed up inside the Bearing Sleeve.
  9. #9 Re: 20 Mimute Wheel Bearing......HA!
    PA
    Quote Originally Posted by Lvgrandprix2003 View Post
    Was the torch the first thing you tried? Or did you try a puller first?
    And hope you used anti-seize on the new one.
    2001 GSE
  10. #10 Re: 20 Mimute Wheel Bearing......HA!
    Cincinnati
    Quote Originally Posted by Zef_66 View Post
    Yes on both, the pressure got so great it started eating into the cv axel!
    But yes, dobbed it all over!
  11. #11 Re: 20 Mimute Wheel Bearing......HA!
    Windsor (ON) Canada
    Like I said in my old post (Ill be up at school for 4 more weeks), got 9 days left, not moving the car until the trip home then right to work on replacing it. I hope I wont have to resort to this?
    Can you think of anything that you did during this install that would have caused you to have to resort to cutting?, or did this just simply happen itself?
  12. #12 Re: 20 Mimute Wheel Bearing......HA!
    Windsor (ON) Canada
    When I do install my new HUB, how do these torque numbers look??, I used them for my first replacement, and got them from off of the thread
    http://www.grandprixforums.net/f73/h...ubs-10985.html (How to replace front hubs)
    -Hub bolts: 96 foot lbs
    -Brake Calliper bolts: 133 foot lbs
    -36 mm axel bolt: 159 foot lbs
    -tire bolts: 100 foot lbs
    Im just wondering if the hub itself was bad in the first place, or that I over/under torqued something.
  13. #13 Re: 20 Mimute Wheel Bearing......HA!
    Charles City, IA
    They look right. I have never had an axle seize that bad. Normally the BFH or an air hammer will loosen it right up.
  1. going on 4th Wheel Bearing
    By Toofastgs in forum Brakes/Suspension/Chassis
    Last Post: 05-16-2014, 04:24 PM
  2. Wheel Hub Bearing questions?
    By dew1520 in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2009, 08:42 PM
  3. ZZP Wheel Bearing - Any good?
    By nickbuol in forum Brakes/Suspension/Chassis
    Last Post: 08-06-2009, 03:31 PM
  4. Replacing wheel bearing
    By robahr24 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2008, 03:51 AM
  5. Wheel bearing questions...
    By Iron Indian in forum Brakes/Suspension/Chassis
    Last Post: 09-21-2008, 11:05 AM
