Thread: Cigarette Lighter Fuse
Results 1 to 2 of 2
  1. #1 Cigarette Lighter Fuse
    SE Level Member matthew911's Avatar
    Feb 2010
    My 2000 GP GT seems to have an electrical problem. The cigarette lighter(s) worked fine for me for the first couple months I've had the car. Suddenly it constantly blows fuses, and it happens immediately when I try inserting a new fuse. Does that indicate a wiring problem? And does anyone know for sure if the lighters are the only thing controlled by this fuse? There are two lighters (technically I guess one is just an aux power), and neither works now, so I'm guessing they both use the same fuse.
    How much of a pain is it to rewire the lighters if that's the problem?
  2. #2 Re: Cigarette Lighter Fuse
    Willoughby, Ohio
    there is a short causing the fuses to blow, might be a shorted socket
  1. brake lights, cigarette lighter, turn signal wont work
    By dlouis30 in forum General Tech Discussion
    Last Post: 03-03-2010, 10:31 AM
  2. Brake light, turn signal, cigarette lighter wont work
    By dlouis30 in forum Introductions/Noob Questions
    Last Post: 03-02-2010, 10:07 PM
  3. Cigarette Lighter Problems
    By missyfisch in forum Audio, Security & Visual Electronics
    Last Post: 10-08-2009, 09:39 AM
  4. problems with a/c controls and cig lighter/charger fuse and low trac system
    By grandprixgt in forum General Tech Discussion
    Last Post: 06-16-2009, 07:51 PM
  5. Removing ash tray/rearranging cigarette lighter?
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 04-17-2008, 05:32 AM
