I have a 2000 Grand Prix, and the front passenger side door has stopped opening. I can still hear the lock moving slightly, but when I (partially) removed the door panel I could see that it wasn't going anywhere, even if I assisted it by hand. I can't remove the door panel completely since the door is stuck closed, but I can get it far enough to do some work. Any suggestions? Since the majority of this work will most likely have to be done by touch alone any sort of diagram of the door would be much appreciated, especially one that shows the locking system in depth.
Thank you!
