Thread: bad window switch help (GTP)
Results 1 to 17 of 17
  1. #1 bad window switch help (GTP)
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    My sons window switch has gone bad. Is there a way to roll up the window w/o the switch? It a 2 door and the drivers side window.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  2. #2 Re: bad window switch help (GTP)
    Barksdale AFB, LA
    I'd imagine that pulling the switch and shorting the pins with a paper clip would make it go up. Need to figure out which pins, though...
    If it's like the Impala/Monte switches, you could take it apart and turn the contacts around. That way you have fresh metal to work with and the switch should work for a while after that.
    2009 Subaru Impreza WRX STI
  3. #3 Re: bad window switch help (GTP)
    St Louis MO
    The connections to the switch didn't operate as I expected. I even pulled out my Fluke meter and checked the wiring. I did find out the dark blue wire needs source voltage applied to it for the window to roll up. Hopefully there will be enough time this evening to give it a try.
    2010 Camaro SS LS3
  4. #4 Re: bad window switch help (GTP)
    Barksdale AFB, LA
    Hope this helps, bud. Looks like you'll short pins A and F.
  5. #5 Re: bad window switch help (GTP)
    SE Level Member AlmightyBirdman's Avatar
    Chicago, IL
    ok I'm going to try to explain this as best as I can but if you press up and down on the clear plastic rockers and look you'll see that it triggers these copper pins to roll the window up and down. Looking at the switch from the drivers view, push down on the copper pin with a paper clip on the bottom left corner outside of the rocker CAREFULLY or else sparks will start flying, and that should do the trick. Here's the write up for the window switch fix:
    http://www.grandprixforums.net/window.php
    This worked perfectly and fixes the issue. I just cleaned up all the contacts and switched out the white pieces with one of the rear windows and everything works perfect!
  6. #6 Re: bad window switch help (GTP)
    St Louis MO
    Is that the Impala one? I'm somewhat sure that's not the layout on my son's GTP.
    Credit to Bizz on the STL board for this:
    switch connections:
    Pin
    Wire Color
    Circuit No.
    Function
    A
    BRN
    165
    Power Window Motor Left Front Down
    B
    TAN
    167
    Power Window Master Switch Right Front Down Signal
    C
    Not Used
    D
    GRY
    8
    Instrument Panel Lamp Supply Voltage - 1
    E
    DK BLU
    164
    Power Window Motor Left Front Up
    F
    LT BLU
    Power Window Master Switch Right Front Up Signal
    G
    BLK
    750
    Ground
    H
    YEL
    143
    Accessory Voltage
    As I recall, the A-D ones seem to follow with the one I was looking at last night.
    2010 Camaro SS LS3
  7. #7 Re: bad window switch help (GTP)
    St Louis MO
    Thanks to both of you guys.
    I ordered a new set of switches from Pace earlier. His switch has lost the click and feel that the other switches have, so I believe it's not dirty contacts causing the problem. I did see the write-up but the pictures were blurry and some of the details that I needed were missing. A great write-up though.
    AlmightyBirdman, your info should be added to the write-up...thanks, that was what I was looking for.
    2010 Camaro SS LS3
  8. #8 Re: bad window switch help (GTP)
    Chicago, IL
    No problem, glad it worked. That's how I had to roll up my window for over a year before I saw that write up lol.
  9. #9 Re: bad window switch help (GTP)
    St Louis MO
    Quote Originally Posted by AlmightyBirdman View Post
    I cant try this until later this afternoon, but I'm sure it will work.
    2010 Camaro SS LS3
  10. #10 Re: bad window switch help (GTP)
    Barksdale AFB, LA
    I pulled the information for mine right out of the GM SI service manual. You didn't post the year of your son's GTP, so I had to guess and went with 2001. I don't know if there were differences over the years.
    It might've been the fact that your son's is a two-door and the connector I found was one of two for a four-door switch.
  11. #11 Re: bad window switch help (GTP)
    Chicago, IL
    Quote Originally Posted by IndeedSS View Post
    ahh I see, but yeah it should work, just be careful the paper clip doesn't slip or else it will spark. It doesn't short anything it but it stings your hand a little
  12. #12 Re: bad window switch help (GTP)
    St Louis MO
    Hmmm, I'll let my son roll up his own window then
    2010 Camaro SS LS3
  13. #13 Re: bad window switch help (GTP)
    St Louis MO
    Thanks again guys. The writeup worked like a charm. Even the switch with the worn down tip works. We will just hold on to the new one until the "repaired" switch dies again.
    fwiw, after looking at the switch up close I can see why pushing on the lower left corner should raise the window, however, I couldn't get it to work. To me it looks like you would have to push up on the rocker so the upper right corner breaks contact like it does during normal operation while using the paper clip method on the lower left. It's either that or the lower left contact was so dirty, it wasn't making a good electrical connection. IDK.
    However thanks again guys everything was good info.
    2010 Camaro SS LS3
  14. #14 Re: bad window switch help (GTP)
    Chicago, IL
    Good to know you got it fixed, sorry that that little trick didn't work, but at least you got the switch fixed up!
  15. #15 Re: bad window switch help (GTP)
    St Louis MO
    It's cool. It may not have helped me this time, but sooner or later it will help soomeone else out.
    2010 Camaro SS LS3
  16. #16 Re: bad window switch help (GTP)
    Louisville, KY
    If you ever need a replacement part, you might want to check with Ed Morad first. He'll definitely be cheaper than a parts store and usually ships the same day.
    My Cardomain
  17. #17 Re: bad window switch help (GTP)
    stearns kentucky
    has anyone changed a key switch on a 2000 GTP
  1. Repair Your Power Windows Switch[*]
    By J_Ferguson in forum How To Write-Ups/Tech Tips
    Last Post: 10-19-2013, 01:07 AM
  2. Ignition Switch Replacement?
    By 02BlueGT in forum General Tech Discussion
    Last Post: 04-06-2008, 08:59 PM
  3. window switch trim
    By kingd44 in forum The Rant Forum
    Last Post: 03-23-2008, 08:38 PM
  4. Rough shifting, switch to Dexron VI?
    By Deezul_AwT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-20-2008, 12:20 PM
  5. Relocate HUD switch [*]
    By Toasty in forum How To Write-Ups/Tech Tips
    Last Post: 01-27-2008, 07:03 PM
