Thread: Driving 99 GT across country 150k mi - Preventative maint?
Results 1 to 13 of 13
  1. #1 Driving 99 GT across country 150k mi - Preventative maint?
    Baltimore
    I'm moving to California for a year sometime within the next couple months, and I will be driving my 99 GT with whatever I can stuff in it there. It's about 2900 miles, probably 34-3500 with side trips to see things.
    • 1999 GT - 153k Miles
    • Original owner
    • Mobil 1 High Mileage Synthetic every 5k (Blackstone says I can go well past that)
    Within the last 5-6 months I've done:
    • Brake pads all around
    • Suspension all around
    • New tires
    Plan to:
    • Oil change before leave (obvious)
    • Clean K&N Filter
    • Coolant flush (I noticed last week temp was a little hot and it was a reasonably cool few days- its never had a flush before, that's original coolant.)
    • New bulbs / headlight adjustment (i feel like they are kinda dim and its probably about time for them to go)
    Anything else anyone suggests?
    After some reading I noticed a lot of people having trans issues at 180k? Something for me to worry about?
    I think that's everything....
    Thanks,
    Drew
  2. #2 Re: Driving 99 GT across country 150k mi - Preventative maint?
    SE Level Member gahris's Avatar
    Ottawa
    I got on trips that are about 2k every 2 months or so, and before every trip I bring the car into the local speedy for an oil change, while its up on the lift they check the suspension and brake wear. So i just check balljoints/suspension, all fluids and belts.
    Keep in mind I am 100% ontop of any issues on my grand prix so everything else is in perfect condition
    Current Car: 2006 Grand Prix GT
    Prevous Car: 1995 Monte Carlo LS
  3. #3 Re: Driving 99 GT across country 150k mi - Preventative maint?
    Apr 2009
    stockton ca
    maybe new plugs , trans flush, but as long as its running well now you shouldnt have much of a problem
    what part of cali you moving to...
    Id make sure you lim gaskets are good proabably are if you havent noticed any coolant loss
  4. #4 Re: Driving 99 GT across country 150k mi - Preventative maint?
    Oct 2008
    Northern Illinois
    If it's running hot check the tstat, they're like 10 bucks if you've never replaced it before it's a good idea. Sparks wouldn't hurt if it's been awhile. I disagree on the trans flush though if it's never been done before I would test the waters after for awhile before taking it on a road trip. I've seen trans flushes shock the tranny on high mile cars.
  5. #5 Re: Driving 99 GT across country 150k mi - Preventative maint?
    Charles City, IA
    Quote Originally Posted by BwolfGT View Post
    A transmission flush will not hurt the transmission.
    SMGPFC Two Nipple General
  6. #6 Re: Driving 99 GT across country 150k mi - Preventative maint?
    Oct 2008
    Northern Illinois
    Meh
  7. #7 Re: Driving 99 GT across country 150k mi - Preventative maint?
    Apr 2009
    stockton ca
    ive never seen a trans flush hurt a trans unless it was already severly damaged
  8. #8 Re: Driving 99 GT across country 150k mi - Preventative maint?
    Check your spare tire. Make sure it is in good shape and holds air. Also, check the jack that comes with it, and if you have room, get a small floor jack. The jacks that come with the car suck and if you get a flat, the floor jacks are a million times easier to use.
  9. #9 Re: Driving 99 GT across country 150k mi - Preventative maint?
    Baltimore
    I believe I have 180 deg tstat, though its pretty old as far as I remember. Can't hurt to replace I suppose.
    I wont do a trans flush, too many issues can come from that IMO.
    Quote Originally Posted by TCO View Post
    Good call! I would assume the widow maker is fine, but I'll check it anyway.. never had to use it. I do have a torque wrench I keep in the trunk, maybe I'll throw a small floor jack in there and dump the widow maker.
    Thanks for all the replies.
    BTW, I'll be living in the bay area. My fiance has a year left of school and I decided since I can finish most of my degree via online classes I would transfer my work position out there until she is done then we may move back. I need to get away after this last snow. I'm ready for tacos and bonfires on the beach.
  10. #10 Re: Driving 99 GT across country 150k mi - Preventative maint?
    Topeka, KS
    Sounds like you got it all covered. Have a safe trip across country post up any cool pictures!
  11. #11 Re: Driving 99 GT across country 150k mi - Preventative maint?
    CT
    Honestly I'd just do the trans flush. All your doing is letting the fluid drain and then filling with new stuff and a new filter. I wouldn't worry about it hurting anything as I myself have done this to 2 different vehicles without any problem. Your going to be driving in a rather hot climate, you should get the trans taken care of with that many miles.
  12. #12 Re: Driving 99 GT across country 150k mi - Preventative maint?
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    when i drove from sw iowa to branson i had a little trouble with my trans when i got back i dropped the pan and changed filter. that gets rid of debris that have built up and you get some new fluid in it but not all of it so its not a radical change but other then that it sounds like your well on your way. good luck and have fun in cali
    silver 2003 Grand Prix GT List is on it's way to be updated
  13. #13 Re: Driving 99 GT across country 150k mi - Preventative maint?
    Apr 2009
    stockton ca
    If a trans flush hurts your trans it was dead anyway
    And with a cross country trip you will be going from sealevel into higher elevation and back down and im guessing you will have a bunch of stuff in your car so added weight
    A trans flush is a smart move
    WHat part of the bay will you be moving to I lived out there most of my life
  1. Country Music fans...
    By joshua_arndt in forum Off Topic Discussion
    Last Post: 11-20-2009, 01:27 PM
  2. drag racing in the country =)
    By nicksilvergt99 in forum Track Sessions and Kills
    Last Post: 11-16-2009, 04:15 PM
  3. 150K suspension refresh
    By Smokin2000gtp in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 08:14 PM
  4. It's Official. This Country Is As Stupid As A Brick
    Last Post: 11-07-2008, 10:10 AM
  5. Corolla spark plug wire change (general maint. question)
    By 04CompG in forum Off Topic Discussion
    Last Post: 09-16-2008, 03:21 PM
