Thread: rear o2 sensor
Results 1 to 18 of 18
  1. #1 rear o2 sensor
    richmond
    Was wondering if there was a way around the second o2 sensor. like maybe plugging in some resisters instead of that $60 fix from zzp .... anyone kno anything about these? if so what would i need to fix it? thx
  2. #2 Re: rear o2 sensor
    if youve got a tuner you can set the code to no report in the PCM and it will never pop up again. otherwise if you cant do that you need an emulator. a resistor does not emulate the o2 signals because the o2 signal is not static.
  3. #3 Re: rear o2 sensor
    richmond
    i dnt have a tuner.... how much wld it b to get it tune or do u kno anyone who could do this for me? i have was reading about the 01 and up have problems with this all the time
  4. #4 Re: rear o2 sensor
    just replace the rear o2 sensor, that is your cheapest option. removing the cat will give you zero gains in performance, so if you already did that then kudos to you.
  5. #5 Re: rear o2 sensor
    Troy OH
    it'll make your car run horribly if you don't fix it, and cause other stuff to go bad. you wouldn't have to go to zzp for it, go to autozone or some parts place to get it. pick up a can of PB Blaster and make an afternoon out of it
  6. #6 Re: rear o2 sensor
    Charles City, IA
    I have the emulator in mine and it works fine. I had a lean code until I put in the emulator in.
    SMGPFC Two Nipple General
  7. #7 Re: rear o2 sensor
    SE Level Member GTPcoupe's Avatar
    Feb 2010
    Canada
    For those of you using an emulator, did you move the wiring to the rear 02 up into the engine bay and mount the emulator there or can you just plug it in underneath. I figured the heat from the exhaust might damage the emulator...
    '99 GTP coupe - Growing mod list/summer car
    '98 GTP Sedan - Winter ride, 315,000+kms and going strong!
  8. #8 Re: rear o2 sensor
    you can plug it in wherever you want and zip tie it off. FYI, i had mine underneath my car still.
  9. #9 Re: rear o2 sensor
    Charles City, IA
    I have mine up in the engine bay.
  10. #10 Re: rear o2 sensor
    richmond
    well i already took the cat off...... so what wld b my best bet for fixing this withput having to buy a cat, do you think it would work if i just put an o2 sensor back in the pipe without a cat?????
  11. #11 Re: rear o2 sensor
  12. #12 Re: rear o2 sensor
    GT Level Member rolyat's Avatar
    OKC
    I saw a write-up on how to build an O2 emulator somewhere when I did a google search. You just need to buy about $6 worth of stuff from radioshack and get to soldering.
  13. #13 Re: rear o2 sensor
    Oct 2008
    Northern Illinois
    I still have to get my code tuned out.
  14. #14 Re: rear o2 sensor
    Quote Originally Posted by rolyat View Post
    if youre talking about a resistor setup, that doesnt work. the signal from the sensor is a WAVE, not LINEAR.
  15. #15 Re: rear o2 sensor
    OKC
    they used more than just resistors... I can't remember exactly what it consisted of. There is a writeup out there somewhere, Im just to lazy to find it again lol. But they said it worked.
  16. #16 Re: rear o2 sensor
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by boostedgtp2003 View Post
    It might work if you put a bung on the pipe, then a 1-2" extension from that bung and screw in the rear 02 to that. The idea is that it still sees enough exhaust to function, but does not throw a code because it is not placed in a free-flowing section.
  17. #17 Re: rear o2 sensor
    May 2008
    McHenry IL
    ses light who cares just scan frequently like i do lol
  18. #18 Re: rear o2 sensor
    Feb 2010
    USA
    a spark plug fouler works fine in mine, no ses lights on, no cat...$5 at the local autozone. take the fouler ( you get 2 in the package) and drill one out with a 1/2" bit, screw the 02 into it, then screw the o2 and drilled out fouler into the other non drilled fouler that came in the package. then screw into pipe..
  1. Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    By Sinister Performance in forum PCM Tuning
    Last Post: 10-27-2017, 12:55 PM
  2. Help! Rear knock sensor
    By cav in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-26-2010, 12:26 PM
  3. Rear Knock sensor P0332
    By cav in forum Introductions/Noob Questions
    Last Post: 03-26-2010, 07:51 AM
  4. Removing rear O2 sensor
    By Black18Ice in forum General Tech Discussion
    Last Post: 11-06-2009, 02:51 PM
  5. rear o2 sensor
    Last Post: 02-22-2009, 08:53 AM
