Does anyone know what size that o-ring is?
I just failed the dorman/motormite drain and i just want to change the o-ring from now on because the new drains come with a small o-ring.
TIA
TIA
TTT
I am trying to get this resolved so no one deals with the same problem i had. I suspect that the o-ring motormite or needa a drain is incorrect or not wide enough to use for a long time.
My drain worked initially but took a crap several miles down the road.
If the width is too small the oring is just going fill the groove up and there will not be enough squeeze on the o-ring.
Call advance and have them cross reference the number you got they will give you the correct #
i need a good source for a radiator to tell me what size o-ring that drain is! I measured the o-ring i got from the dealer today because i ad to drain thew coolant and replace the ****ty autozone coolant temp sensor.
Measurement was close to 12 x 6 x 3mm
