Thread: porting
Results 1 to 4 of 4
  1. #1 porting
    Joliet, IL
    what supplies will i need to home port my blower and TB? and where can i get em thanks! gtp is down for a couple weeks and i need something to keep me busy.
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: porting
    Banned - Busted For Scamming
    Feb 2009
    Inlet or outlet?
    Plan on a die grinder, extended carbide bits, flap wheels, dremel, sanding rolls for the very minimum. Ideally you would want to machine the inlet and outlet but if you dont have the tools...
  3. #3 Re: porting
    Joliet, IL
    Inlet or outlet?
    just wanna open up the outlet remove the hbar and open up the LIM....
    00 Silvermist GTP
  4. #4 Re: porting
    A bit and a dremel
    You could use a 1/2" drive bit/dremel and it wouldn't be that terribly slow.
    And why would you want to remove those things?
    Is your blower ported already?
    Planning on going I/C'd?
  1. Porting Gen 5 M90
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2010, 02:38 AM
  2. boring &porting
    By CHAMPS97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2009, 11:44 AM
  3. TB Porting ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 06-01-2009, 12:10 AM
  4. Porting the LIM and SC?
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2009, 09:41 AM
  5. porting
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-23-2008, 05:29 PM
