Thread: Throttle Body Spacer/Coolant Flow
Results 1 to 9 of 9
  1. #1 Throttle Body Spacer/Coolant Flow
    GT Level Member TeeWX's Avatar
    Apr 2009
    Cresco, Iowa
    I had an engine with a throttle body spacer on it that I picked up for spare parts. The idea of putting a piece of plastic between two pieces of aluminum to stop heat soak in theory does seem like a decent idea. Well I know that throttle body spacers block off the coolant passageway and can cause problems. Has anyone ever thought to machine a new passage? I mean it seems like you could do it right on the inlet if I'm not mistaken.
    Any thoughts on this? Otherwise I geuss I have no use for that TB spacer haha.
  2. #2 Re: Throttle Body Spacer/Coolant Flow
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    why would you do that? why would you want the throttle body hot? you want it cold block that shyt off "hence" cold air intake =better performance and more hp
  3. #3 Re: Throttle Body Spacer/Coolant Flow
    GTX Level Member real diehl's Avatar
    Salina, KS
    Quote Originally Posted by imdaman3 View Post
    lolwut?
    There's several threads regarding this already. Coolant flow into the throttle body was apparently done to keep frost off the buttefly/tb blade I believe. Blocking the coolant shouldn't hurt anything. I'm not sure how many people block all coolant going into the blower to be honest.
    signature removed for inappropriate content.
    -bio
  4. #4 Re: Throttle Body Spacer/Coolant Flow
    Feb 2010
    ohio
    Quote Originally Posted by realdiehl View Post
    lolwut?
    well thats what ive always been told by the older guys that race cars especially lt1/ls1 cars, less heat at throtle body the more cold air get into the motor
  5. #5 Re: Throttle Body Spacer/Coolant Flow
    these blower cars dont need cold air..they need MORE air.
    TW, drill and tap the LIM instead of plugging the blower. there are two holes that youll need to cover. however, once you do this youll also have to pop off the end cap on the drivers side of the LIM and open that up a little more too so that the coolant flow to the rear head isnt compromised. part of the flow to the rear head is what normally flows through the throttle body and blower.
    then once you stop coolant from going to the throttle body youll never need a new throttle body gasket ever again.
  6. #6 Re: Throttle Body Spacer/Coolant Flow
    GTP Level Member Scimmia's Avatar
    QCA, IA
    colder air = denser air = more air.
    2001 Buick Regal LS - Almost Stock
  7. #7 Re: Throttle Body Spacer/Coolant Flow
    Quote Originally Posted by Scimmia View Post
    Remember we're dealing with the heaton here. It pretty much negates minor air temp changes.
  8. #8 Re: Throttle Body Spacer/Coolant Flow
    Donating Users Warbeaver's Avatar
    St. Louis
    if you have wrapped headers/manifolds with cooler t stat and fan turn on points, the tb shouldnt get hot. I even took my TB heatshield off and the TB doesnt get hot. its much cooler using that tb spacer
  9. #9 Re: Throttle Body Spacer/Coolant Flow
    agreed, but to some degree the cold air doesnt matter.
  1. Throttle body spacer
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2010, 08:21 PM
  2. Throttle body spacer?
    By 05PontiacGP in forum General Tech Discussion
    Last Post: 03-04-2010, 09:09 PM
  3. throttle body spacer
    By danross in forum General Tech Discussion
    Last Post: 02-19-2009, 06:40 PM
  4. throttle body spacer
    By NKYspdemon in forum Off Topic Discussion
    Last Post: 06-30-2008, 08:45 PM
