jaetawright
Bump for this question as it is a project that I would like to undertake as well. I have a 08, non-GXP. From what I can tell only the GXP's had the fog/turn signal lights. There is a 4 wire plug that includes an un-used purple wire. I assume that the purple wire goes to the fog light control. In my fuse block under the hood, fuse #7 (10 amps) says fog lights, and there should be a wire that interfaces withe the computer to turn the fogs on and off. Which wire is it? I have tried tracking it down with a multimeter, and was only able to disconnect my hi-beams.
Like the OP, I am not really interested in modding, rather would like to use the cars existing wiring to do the job. I know the wires are there, just dont know which ones to use, ore what signal to give them (+12 or ground). Any help would be appreciated.
Thanks,
Jon
