Thread: Filling Up takes 20 minutes...
Results 1 to 20 of 23
  1. #1 Filling Up takes 20 minutes...
    SE Level Member White Cerebus's Avatar
    Michigan
    When I fill up my tank, with in a minute the nozzle turns off and gas has pushed back up the filler tube. If I wait a second or two, it flows down and I can continue, for another 10 seconds. Rinse and repeat. Now at this point, its not so bad, the weather is finally shaping up. But when its cold out its even worse and I've take well up to half an hour trying to fill up. I have a 14 gallon tank size. And so I'm wondering, why would it do this? Is something clogged? I know its not just the gas station because this problem persists at everyone of them. Help?
    2dr 99 Grand Prix GT driver.
  2. #2 Re: Filling Up takes 20 minutes...
    Apr 2009
    stockton ca
    a kink in the filler neck maybe or someone could have put something in ur filler neck
  3. #3 Re: Filling Up takes 20 minutes...
    I have a similar issue but it'll shut off within a second or two EVERY time, just pull it half outta the filler neck and it should fill normally.
  4. #4 Re: Filling Up takes 20 minutes...
    Donating Users ls6velless454's Avatar
    Nov 2009
    Portage, IN
    It could also be something to do with the vacuum in the gas tank, from the evap not returning idk
    There is no replacement for displacement........unless you have a supercharger or turbo
    2000 Bright Red GTP Coupe GXP axle back, GMPP sway bar, NGK TR6, 180 stat. (Uninstalled Aeroforce Interceptor, DHP PCM, FWI, Gen V on the way) and still no pulley in sight.
  5. #5 Re: Filling Up takes 20 minutes...
    GT Level Member skidoojames151's Avatar
    seattle
    GP's have 17 gallon tanks...
  6. #6 Re: Filling Up takes 20 minutes...
    Quote Originally Posted by ls6velless454 View Post
    This might make some sense since my EVAP solenoid clicks so loudly I thought it might have been my injectors.
  7. #7 Re: Filling Up takes 20 minutes...
    Michigan
    I tried pulling it half out, and still the fuel backs up and the nozzle turns off.
    So, how do i fix:
    A) A kink in the filler neck?
    B)Vacuum in the gas tank?
  8. #8 Re: Filling Up takes 20 minutes...
    GTP Level Member Scimmia's Avatar
    QCA, IA
    It's most likely a problem with the EVAP vent canister/solenoid not allowing the tank to vent correctly.
    2001 Buick Regal LS - Almost Stock
  9. #9 Re: Filling Up takes 20 minutes...
    Delaware, OH
    Quote Originally Posted by Scimmia View Post
    Possibility.
    Also could be the check ball in the filler neck. They can get stuck and not allow fuel into he tank in a timely manner.
    Also seen where people have put stuff like marbles and ball bearings into peoples tanks and they get caught in the the neck. try sticking a magnetic pick up tool down there and see if it pulls anything out.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  10. #10 Re: Filling Up takes 20 minutes...
    Feb 2008
    West Jordan, UT
    How long do you go between fill ups? Mine does this every single time I let it get below about an eighth of a tank. It has never done it when I fill up at about a quarter.
  11. #11 Re: Filling Up takes 20 minutes...
    Michigan
    I stuck a magnetic rod down, and didn't bring out anything.
    As far as between filling up, it varies. But no matter how much gas I have in it before I start, it always backs up and turns the nozzle off.
  12. #12 Re: Filling Up takes 20 minutes...
    Minnesota
    Bringing this back from the dead. I have this issues also. I can only assume its the filler neck or I was thinking the pressure sensor if that even has anything to do with the venting of the gas tank. What did you end up finding out about this?
  13. #13 Re: Filling Up takes 20 minutes...
    rip it apart and check for foreign materials?
  14. #14 Re: Filling Up takes 20 minutes...
    I live here. TLSheff's Avatar
    Mine does this too. Like That Canadian Guy said tho, pull it out about half way and it works like a champ.
    I read a report, not too sure on how accurate it is but it was pretty convincing. It stated that your actually only suppose to pump gas on the lowest setting, the 1st little notch on the clicker thingy (technical term ). The stated reason for this is that when you pump gas and just hold it to the max or notch it up as high as it will go, it pumps so quickly the pressure causes the fumes to come back out and a rapid pace. Now whether or not you realize but the liquid part is not what really burns, the fumes is what the engine really burns off of. So by pumping at a fast rate your really expelling extra fuel, which is a loss in $$$, a waste of fuel, and its not good for the ozone if your all about the environment. Try it next time your at the pump, you can literally see the fumes coming out on the max setting, then notch it down... not as noticeable.
    Probably not really enough to make much difference in the pocket book, but I also noticed that it doesn't take much longer pumping at a slow rate vs the max setting, but without the hassle of it clicking off over few seconds. Food for thought, may save you some money in the long run too
  15. #15 Re: Filling Up takes 20 minutes...
    fuel mists.
    atomizes.
    becomes vapour.
    its the beauty of injectors.
    fine mist burns better than a hose of fuel.
  16. #16 Re: Filling Up takes 20 minutes...
    Chilliwack BC
    Sounds like it isn't venting. there is a tube attached to the filler neck that vents the air when you pump gas into your tank.
    think of it like an apple juice container. if you open it and start pouring it chugs on it's way out. but if you cut a hole in it it pours smooth.
    hope this helps.
  17. #17 Re: Filling Up takes 20 minutes...
    Kansas
    Quote Originally Posted by Couch View Post
    Or think of it like shotgunning a beer.
    SOLD 1999 GT Silvermist TS
  18. #18 Re: Filling Up takes 20 minutes...
    Chilliwack BC
    Quote Originally Posted by GAFF View Post
    ya without cracking the can tab lol
  19. #19 Re: Filling Up takes 20 minutes...
    Minnesota
    So its probably the filler neck. It's more annoying than it is harming anything. I do pull out half way but if I have learned anything in life, pulling out half way can only cause more problems down the road. lol
  20. #20 Re: Filling Up takes 20 minutes...
    SE Level Member charlie31603's Avatar
    Jul 2008
    Tampa, Florida
    Back from the dead again. Got a friend that has the same problem on his 98 Daytona. I just changed the filler neck down to the rubber hose and it still does it. Doesn't matter if you pump slow, fast, nozzle in or half out. It still takes forever to fill. He drives it a lot as a DD. So it's a pain to have to fill it up every other couple of days when it takes an half hour. So any one that had this problem fix it yet?
    1999 Pontiac Montana with a loud whine
  1. Engine Quits After 30-45 Minutes
    By DanGale in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-25-2010, 01:22 AM
  2. Runs 5 minutes...Stalls...Changed everything
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2009, 02:47 PM
  3. AC only takes 7oz of freon?
    By SuperSport in forum General Tech Discussion
    Last Post: 07-07-2009, 06:39 PM
  4. Can filling the divots in the blower throw an EGR code?
    By Infinity9999 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-18-2009, 01:34 PM
  5. Filling supercharger slits and egr.
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2009, 08:52 AM
