Does anyone have a write-up to replace the ignition switch, cause I need to do this, and cant find a write-up anywhere... thanks for any responses
Moved this over to the tech lounge. You might click on the How To link at the top and see if we have one in there or not, Im not sure if we do or do not. I know there is one out there somewhere because its what I used when I did mine.
I know I've seen one, but there was only the ignition relay mod in our How to Section
Okay, if you dont find it, I'll try and get what I have posted up. It is not my How To, I did not make it up and Im not sure who the credit goes to. You might check the other site because I got it off there.
I dont mind posting it up here, I just would feel better if the original author knew about it.
^^^ understandable, I found it, and you've got a PM![]()
Also, would Dielectric grease help prevent the arching that causes the carbon build-up?
Toasty, forgive me, but I forgot you had done a version of that. I should have remembered since it was plug and play.
Heres the one i used. Everything is pretty much straight forward but its always nice to have some kind of reference. ClubGP Message Forum troubleshooting
