Thread: Engine stalls within seconds of starting
Results 1 to 8 of 8
  1. #1 Engine stalls within seconds of starting
    SE Level Member wadehosic's Avatar
    Firth, NE
    The engine starts fine but dies almost immediately. If I give it gas to keep the RPMs around 3000, it still dies after a few seconds. The pressure switch on the fuel rail will squirt fuel if I depress it. Thoughts?
  2. #2 Re: Engine stalls within seconds of starting
    West Side Michigan
    What year is your car? Because some keys have a chip in them and if you get a copy of a key and don't have the chip in it, the car will start fine and then die. Yea I went and made a copy and tried starting the car and then it died.
  3. #3 Re: Engine stalls within seconds of starting
    Willoughby, Ohio
    MAF sensor? fuel pump? fuel pressure regulator? my car did the same thing and it was my MAF sensor. if you unplug it and the car starts, its a bad MAF. as far as the other things go, i havent had them go bad i just know they could possibly cause that
  4. #4 Re: Engine stalls within seconds of starting
    Firth, NE
    It's a '97 but not a new key.
    CTKGP09 - will the car run with the MAF unplugged? Or should it not start at all with the MAF unplugged?
    It acts as if it is starved for fuel after a few seconds so it could be the fuel pressure regulator or my father in law thinks it might be the throttle position sensor.
  5. #5 Re: Engine stalls within seconds of starting
    Donating Users bigmeadersGTP's Avatar
    illinois
    Try bypassin the fuel pump resistor...
    Its low, its fast, but most of all....its black.
  6. #6 Re: Engine stalls within seconds of starting
    Willoughby, Ohio
    yes if the car starts with it unplugged then the MAF is bad, if you unplug it and the car still doent start then its something else. the throttle position sensor is a good guess too...forgot that one
  7. #7 Re: Engine stalls within seconds of starting
    Firth, NE
    BigmeadersGTP - Bingo! the fuel pump resistor appears to be the issue. When it is bypassed it runs great. I'll pick one up tomorrow and hope to be on the road. Thanks!
  8. #8 Re: Engine stalls within seconds of starting
    Firth, NE
    Fuel pump resistor relocation kit did the trick. Drove 600 miles this weekend with no issues. Thanks everyone for the ideas.
  1. 1998 Gd Prix sputters and stalls when engine warm
    By jmickevi in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2010, 02:05 AM
  2. Starting engine on engine stand?
    By bbptech in forum Off Topic Discussion
    Last Post: 01-13-2010, 01:23 PM
  3. Engine not starting on first turn
    By breuker19 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-08-2010, 08:23 PM
  4. Car starts but stalls after 2 seconds
    By cartooz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2009, 06:18 AM
  5. Has a really hard time starting when engine is hot
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-05-2008, 11:27 PM
