Thread: rough idle
Results 1 to 17 of 17
  1. #1 rough idle
    Indianapolis Indiana
    i have a 2002 gtp no mods I am new to the web site an have found a ton of great info but now i am in a bind. I recently have changed my intake gaskets because of a light leak. Two week later my car is idling rough so i changed plugs wire and coils didn't change a thing so i took carb cleaner to check for vac leaks and nothing. I was wondering if anyone else had any ideas?
  2. #2 Re: rough idle
    Outer Space
    Get it scanned and check Long Term Fuel Scans... try to find a local GTP member and ask them nicely to scan your car.
    Also, any Service Engine Codes? If so, list them..
    Odds are you have a vacuum leak.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: rough idle
    GTX Level Member cerick08GP's Avatar
    EGR maybe. It should be shut at idle, it could have failed open on you. I’m with Goose 100%, you need it scanned. Because it could be several items, especially since you didn’t give a whole lot of information. Anyway, checking out and cleaning the EGR is easy and free.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  4. #4 Re: rough idle
    no codes and i checked egr and it is still working great. do you think it maybe iac?
  5. #5 Re: rough idle
    The car runs smooth as can be at 1300rpm anything below that it gets ruff i just got it back yesterday from having brand new trans installed and he also told me he ran codes on the car an said i had a misfire and possible clogeed cat so thats when i did the plugs wire and coils. Could it maybe the cat?
  6. #6 Re: rough idle
    Charles City, IA
    no, you more than likely have a vacuum leak. Look harder.
    SMGPFC Two Nipple General
  7. #7 Re: rough idle
    Quote Originally Posted by 02gtpalder View Post
    It certainly could be your cat. If your car has over about 120k, that would be in my top 5 list.
    To check it, drive around tonight get the engine heated up. Get on it a little, and then pull over in a dark area. Leave the car running, pop the hood and look at your exhaust piping before the cat (and the cat itself). If it is glowing, the cat is your problem.
    2008GP
    2002GP||sold
  8. #8 Re: rough idle
    wouldn't a vac leak make the idle go up and my exhaust tone is kinda lump sounding almost like a little cam
  9. #9 Re: rough idle
    Does the exhaust smell like rotten eggs?
    2008GP
    2002GP||sold
  10. #10 Re: rough idle
    no eggs smells like gas and my car just hit 140000
  11. #11 Re: rough idle
    Well, if it was my car I’d call up a local shop and have them weld in a universal cat. It is your cheapest option when replacing the cat.
    2008GP
    2002GP||sold
  12. #12 Re: rough idle
    im a certified tig and mig welder so i think im going to just do a delete since we dont have emissions. and then go from there then thanks a bunch for your in put!
  13. #13 Re: rough idle
    I just thought of another cheap easy one, replace your PCV valve. It is a way out there chance like 1:1000, but its two bucks
    Although I’m pretty sure your cat is the issue. I have seen dozens of people that refuse to believe that cats and O2 sensors don’t last forever.
    PS deleteing it will give you a perma CEL
    2008GP
    2002GP||sold
  14. #14 Re: rough idle
    i cant buy the little sensor to trick the o2 sensor off of zzp or dont those work
  15. #15 Re: rough idle
    Honestly, I’m not sure they work for 04+.
    The only method I do know works is the PCM code delete.
    I’d give it a 50/50 chance
    2008GP
    2002GP||sold
  16. #16 Re: rough idle
    ok figured it out guys after putting it on my fathers scanner and drove it #6 was the only one not firing so did compression test it was good so i got to looking and the wires to the plug for injector were bare an breaking so i repaired that and runs great again thanks for everyones help!
  17. #17 Re: rough idle
    I’m glad you found it , just as we suggested in the very beginning you needed to do a scan. I’ll never understand why people are so reluctant to use such a good diagnostic tool.
    2008GP
    2002GP||sold
  1. GTP Rough Idle
    By jaredhagen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2010, 01:32 PM
  2. Rough Idle
    By hacket in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-29-2009, 02:39 PM
  3. '97 GTP, rough idle
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2009, 01:14 AM
  4. Almost rough idle
    By DesQ27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-01-2009, 08:31 PM
  5. Rough Idle
    By Red_GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 02:29 PM
