Thread: Newbie help... 01 Grand Prix Vibration
Results 1 to 6 of 6
  1. #1 Newbie help... 01 Grand Prix Vibration
    Feb 2010
    SD
    I have a vibration that is only happening when I go over bumps( more like Dips) over 50 mph. Also getting similar vibration on the car when I take curves to the right but not to the left.
    I have jacked the car up and the wheel bearings feel okay. There is a little play in the tie rods and ball joints. My father thinks is the combination between the tie rods and ball joints but I don't think so... Can someone give me some insight here.... I don't think its the tie rods and ball joints....
    Help, I don't want to spend money I don't need to.
  2. #2 Re: Newbie help... 01 Grand Prix Vibration
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    sounds like the problem to me anything loose in the front end will make the car shake, especially at high speeds replace the loose parts and go get a allighment before sumthing bad happens
  3. #3 Re: Newbie help... 01 Grand Prix Vibration
    Largo, Florida, United States
    do you had different rims on your car?
    when was the last time your tires were balanced?
  4. #4 Re: Newbie help... 01 Grand Prix Vibration
    Feb 2010
    SD
    I got new tires a month ago and it was still happening before and after.
  5. #5 Re: Newbie help... 01 Grand Prix Vibration
    Carman, Manitoba
    Im getting the same thing, bumps at high speed (vibrates) and right turns under power give harsh vibration on right side, but no vibration on left turns.. I was told on here it was CV joint really confusing...
  6. #6 Re: Newbie help... 01 Grand Prix Vibration
    Outer Space
    My car would bounce at 25-30 mph and the axles would knock around turns before I replaced the cv axles.
    02 GTP 13.6 @ 100mph - SOLD
  1. Newbie: 1997 Grand Prix GT-I finally got a 3.8L
    By andre93 in forum Introductions/Noob Questions
    Last Post: 02-19-2010, 11:55 AM
  2. Newbie from grand rapids,mi
    By 2000SILVERSE3800 in forum Introductions/Noob Questions
    Last Post: 10-02-2009, 01:51 PM
  3. Grand prix newbie!
    By luckytolive in forum Introductions/Noob Questions
    Last Post: 05-26-2009, 06:13 AM
  4. Newbie needs some help on a 98 Grand Prix
    By goatmanjohn in forum General Tech Discussion
    Last Post: 05-03-2009, 11:11 PM
  5. Newbie with a 01 Grand Prix GTP special edtion from SD
    By glanzergtx in forum Introductions/Noob Questions
    Last Post: 01-09-2009, 05:18 PM
