Thread: fuel gauge wiring
Results 1 to 10 of 10
  1. #1 fuel gauge wiring
    SE Level Member BrokenRhythm's Avatar
    Nov 2008
    north plainfield, NJ
    well my fuel gauge hasnt worked since i bought my car about a year ago, so i figured its time to stop modding and start fixing.
    there is already a new complete fuel pump installed and the wiring shows no resistance from the pump to the passenger kickpanel. however there is resistance from the kickpanel to the back of the gauge. does anyone know the wiring behind the dash? or any ideas? the gauge always reads full btw.
    thanks for any input
    97 GTP, Thrasher intake, SLP cat-back exhaust, slp headers, whisper resonator, 3.4 pulley, ssc springs/agx, built trans, 3.29's,ati stall, DHP 1.0, AL 104's, HID's, PRJ wires, 40th interior and hood, 12" brakes, and too much more to list here
  2. #2 Re: fuel gauge wiring
    GTP Level Member SuperSport's Avatar
    Michigan
    A new fuel pump means nothing. The sending unit/float that clips to the fuel pump died and needs to be swapped out. It simply clips to the side of the pump assembly.
    A new sending unit is around $90 at gmpartsdirect.com, and I installed mine in about 1/2 hour.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  3. #3 Re: fuel gauge wiring
    Nov 2008
    i meant to say i replaced the whole assembly, pump, sender, all. complete drop in unit
  4. #4 Re: fuel gauge wiring
    Nov 2008
    i guess this is a new problem where as nobody seems to have experienced this before.
    anybody out there with any ideas before i get knee deep in dash wire looms? at least a wiring diagram?
  5. #5 Re: fuel gauge wiring
    Topeka, KS
    ALLDATAdiy.com :: Leading Source of Diagnostic and Repair Information is awesome for diagrams and helpful info regarding any car. It does cost though.
    Enter REPAIR2010 in the Gift Certificate Code Field for a discounted price of $14.95.
  6. #6 Re: fuel gauge wiring
    Nov 2008
    thanks i appreciate it. ive used it before at my shops and it always comes in handy
  7. #7 Re: fuel gauge wiring
    Nov 2008
    was kinda hoping someone may have a diagram first, if not ill give it a shot
  8. #8 Re: fuel gauge wiring
    Nov 2008
    well i guess its a new problem so ill let everyone know what it is once i fix it to help others down the road
  9. #9 Re: fuel gauge wiring
    SE Level Member nault31's Avatar
    Southside Chicago Suburbs
    I'll see if I can find that in my gm service manual, if I find a diagram I'll post a scan of it.
    ^^I realize a stock L36 is not as fast as the sticker implies, but this sticker has worked and it is still a hell of a lot of fun to drive considering it's a grocery sedan.
  10. #10 Re: fuel gauge wiring
    There should be resistance to the gauge because the sending unit is basically a rheostat that changes the resistance sent to the needle as the fuel level changes. Myself if it's not a loose wire I believe it's the sending unit but I'll send you the problem diagnosis, gauge cluster wiring diagram and sending unit replacement anyway.
    The pdf files are too big for the forum so pm me your email or drop me a line at nault31@gmail.com
  1. Fuel Pump wiring diagram for 1996 3.4L
    By 96LimitedEdition in forum General Tech Discussion
    Last Post: 04-14-2010, 08:39 AM
  2. wiring up my VOLTS GAUGE =] 1 Q
    By GTPJOE90 in forum Audio, Security & Visual Electronics
    Last Post: 09-26-2009, 01:50 PM
  3. Fuel pump wiring diagram for 1996 Grand Prix LE with a 3.4L
    Last Post: 07-23-2009, 01:03 PM
  4. aftermarket fuel gauge wiring
    By momo29 in forum General Tech Discussion
    Last Post: 03-05-2009, 08:09 PM
  5. gauge wiring
    By QwikGT in forum General Tech Discussion
    Last Post: 08-09-2008, 12:46 PM
