Thread: Intercooler Reservoir / Ice Box????
Results 1 to 20 of 23
  1. #1 Intercooler Reservoir / Ice Box????
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Before any says anything...yes I searched! LOL!!!
    I'm looking to do a reservoir in my new intercooler setup. Something that would pressurize my system bleed it. I'd also like to be able to work on maybe constructing some type of ice box for the system also.
    Anyone do anything like this before? Anyone have any ideas??
    For all your 3800 needs:
  2. #2 Re: Intercooler Reservoir / Ice Box????
    GTX Level Member Deimos's Avatar
    iowa
    I had a liquid to air intercooler precision turbo PT2400. It was mounted under ther passenger side dash.
  3. #3 Re: Intercooler Reservoir / Ice Box????
    Charles City, IA
    We made a ice box for my friends pull truck it worked great. It was not pressurized. We took a cooler and ran a small pvc pipe with holes drilled in it along the bottom of the lid, For the return line. Then just drilled a hole in the bottom for the sending line. When hot water came back it melted the ice and got it nice and cold.
    SMGPFC Two Nipple General
  4. #4 Re: Intercooler Reservoir / Ice Box????
    use a 97/98 coolant bottle. fits ice and will bleed the system SUPER easy with it.
  5. #5 Re: Intercooler Reservoir / Ice Box????
    Speaking of I was thinking why dont people use front mount liquid heat exchangers like the 03 04 cobras? seems like it would make a colder charge and be able to fit a larger core instead of the zzp style intake manifold setups.
  6. #6 Re: Intercooler Reservoir / Ice Box????
    Quote Originally Posted by 02GrandPrixIraqVet View Post
    we DO use front mount heat exchangers..
  7. #7 Re: Intercooler Reservoir / Ice Box????
    Donating Users blowfishRus6's Avatar
    g.a.
    i would run a resivor with water and ice in it at the track, but in the wihter time i would not run anything but coolent. ive seen to many people crack intercoolers in the winter time from freezing water.
    i would deff do it if i was going to the track tho.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  8. #8 Re: Intercooler Reservoir / Ice Box????
    Orange County, NY
    car is stored in the winter so I'm not really worried about freezing. I did look into some of the aftermarket supertanks for the cobra's but they are priced in the $200 range, way above my budget.
  9. #9 Re: Intercooler Reservoir / Ice Box????
    g.a.
    just use the stock cobra resiviour......
    its slow.
  10. #10 Re: Intercooler Reservoir / Ice Box????
    Orange County, NY
    I'm trying to locate one now but it's not as easy as I had hoped! LOL
  11. #11 Re: Intercooler Reservoir / Ice Box????
    g.a.
    svtperformance.com
    im sure you should be able to find one there.
    its slow.
  12. #12 Re: Intercooler Reservoir / Ice Box????
    Orange County, NY
    I posted a WTB there, we'll see if I get any bites
  13. #13 Re: Intercooler Reservoir / Ice Box????
    g.a.
    that is probably the route i will go if i go intercooled.
    used fmhe from the cobra, and the resiviour and maybe even the pump if they are selling them cheap enough, probably just go with a gm pump tho. then probably a wbs core.
    if that stuff works on the cobra that pushes out more boost than my car, im sure it will be enough for my car.
    its slow.
  14. #14 Re: Intercooler Reservoir / Ice Box????
    Jan 1970
    Maquoketa, Iowa
    I think we might have a Cobra IC reservoir around, I'll check...
  15. #15 Re: Intercooler Reservoir / Ice Box????
    the cobra reservoir is pretty small if you wanted to have a big amount of ice. like i said, the 97/98 coolant bottle will work very well for what youre looking for.
  16. #16 Re: Intercooler Reservoir / Ice Box????
    Jan 1970
    Maquoketa, Iowa
    True, I have to look at it again, but I don't see any real benefits as it being a ice box, more along the lines of it just being a reservoir tank.
  17. #17 Re: Intercooler Reservoir / Ice Box????
    the ice is gone after a run anyway, but if you wanted to pack the thing tight with ice so that your intake temperatures were nice and low for the run then you would melt it all and heat it up before you even got under way with the cobra reservoir.
  18. #18 Re: Intercooler Reservoir / Ice Box????
    Orange County, NY
    Very true, I'm thinking about running something similar to Sal over at the "other" site:
    ClubGP Message Forum troubleshooting
  19. #19 Re: Intercooler Reservoir / Ice Box????
    ghetto as all hell, but it gets the job done i bet. id also rather have the cold fluid (ice) in the system with the coolant than trying to make the coolant itself cold.
  20. #20 Re: Intercooler Reservoir / Ice Box????
    Orange County, NY
    I think he has it nicely executed actually, wrapped the cooler up nice, looks professional.
    I'm a little skeptical about running no coil in the cooler though.... I don't like the idea of all that water sloshing around in the trunk in a cooler
  1. Where is the Power Steering Reservoir Cap???
    By Quicklynx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2012, 07:13 AM
  2. Cowl Hood and Cobra Reservoir FTW!
    By VinnieGTP in forum General Tech Discussion
    Last Post: 08-28-2008, 04:30 PM
  3. SS intercooler ?'s
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2008, 12:11 AM
  4. which intercooler ???
    By DunriteDiesel in forum Off Topic Discussion
    Last Post: 06-15-2008, 10:40 PM
