Thread: Storing supercharger rotors
Results 1 to 6 of 6
  1. #1 Storing supercharger rotors
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    I imagine this one may be a Farnsworth question, however, how do you lstore supercharger rotors long term? These like most will be mounted on the rotor plate. I want to keep the rotors scratch free, the rotor plate rust/corrosion free and clean and equally important eliminate any stress where the rotors are pressed into the plate.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  2. #2 Re: Storing supercharger rotors
    GT Level Member BackInBlack's Avatar
    Vermont
    Not a SC specialist, but I would think that taking the rotors off the plate and spraying everything with cosmoline (Cosmoline - Wikipedia, the free encyclopedia) and storing each in it's own plastic bag, then wrapped in bubble wrap would be the best bet...
    The GPs are long gone...
  3. #3 Re: Storing supercharger rotors
    Wichita, KS
    ^that would work, or...
    leaving the SC oil on the gear side for protection, and for the rotors, I would get an old but clean hand towel and fold it once or twice depending on the size, and have enough to completely wrap around the rotors 360*.
    What I do when the rotor assembly goes into the polishers, I will interlock the towel in between the rotors, so you kinda screw the towel into the rotor pack gently, then wrap the towel around the rest of the exposed rotors, and then wrap the towel in duct tape to hold the towel in place, and offer even more protection.
    For your storage...getting you a thick, heavy gauge plastic bag, and getting as much air as possible out of it would also be a good idea if they are a good set. All of my rotors and blowers are just stored on an open shelf, as I don't really care...they are getting fully rebuilt anyway.
    ~F~
  4. #4 Re: Storing supercharger rotors
    Saraland Alabama
    so store them like you would an engine except have some padding
  5. #5 Re: Storing supercharger rotors
    Hoffman/Schaumburg, IL
    ^^^ Farns has more M90s than I have clothes...... Wouldnt in the blower case be the best bet? you can pick up cases in the classifieds for cheap
  6. #6 Re: Storing supercharger rotors
    St Louis MO
    DOH! Important piece of information left out. Since my s/c was making a noise, like described in this thread http://www.grandprixforums.net/f81/t...belt-2579.html I ordered another coupler, fluid and a very nice set of rotors. The rotors are mounted on the rotor plate and that's all I'm getting. So I will either be storing this set for a later date or installing them and storing my current set, which very likely is still good.
    You guys have given me so good ideas to work with though.
    2010 Camaro SS LS3
  1. How to remove the supercharger ?
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2009, 04:20 PM
  2. supercharger coupler
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2008, 04:41 PM
  3. How bad is it to run 12" rotors, Front & Back?
    By Incomudrox in forum Brakes/Suspension/Chassis
    Last Post: 04-09-2008, 06:59 PM
  4. Centric pads and rotors. good?
    By 04CompG in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2008, 03:44 PM
