Thread: 2001 coupe manual hvac won't stay hot?
Results 1 to 3 of 3
  1. #1 2001 coupe manual hvac won't stay hot?
    SE Level Member 2001redfireGT's Avatar
    Twin Cities
    Hi, I have a 2001 gt coupe with the driver and passanger slider heat controls. The drivers side will always be at the temp that I slide it to, however, the passanger side will either start cold or when it is hot will all of a sudden go cold. Usually you can make it go back warm by moving it up and down a couple times. It is really getting annoying though. My question is how do I fix this? Can I just get another coupe slider hvac and swap it out? I hope so. Any experience? Really appreciate it
  2. #2 Re: 2001 coupe manual hvac won't stay hot?
    Wooster, Ohio
    as long as its the same climate control as the one you have it will work just fine. Do some junkyard hunting or check out some of the cars being parted on here and find one and swap it out (takes like 10 minutes tops) and that should fix it. Definetly a problem with the controller!
  3. #3 Re: 2001 coupe manual hvac won't stay hot?
    Twin Cities
    Glad to hea. I was hoping so. I will soon look deep into the parting of rides in here soon. Most junk yards here are four doors, so I hope I can help someone out here and pick one up from a part out.
  1. 01 Gp gt vs 07 or 08 altima coupe 2.5s vs infiniti g35 coupe
    By grandprixgt in forum Track Sessions and Kills
    Last Post: 02-26-2012, 05:56 PM
  2. won't stay in 4th?
    By bradford82 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-07-2009, 01:20 PM
  3. Newbie from SC /// 2001 GT coupe
    By possum25 in forum Introductions/Noob Questions
    Last Post: 03-11-2009, 05:12 PM
  4. 2001 service manual
    By Jakegday in forum General Tech Discussion
    Last Post: 11-16-2008, 03:59 PM
