Anyone have a picture installation on these? Or does anyone have pictures of there setups? still stumped, feelin' like a ra-tard
well i talked to a few more people, and i got the understanding of most of it, except the two connectors. Also someone mentioned adding a ground, or splicing or something. Id hate to give up on these but a picture might be all i need
Well, i basically have no idea how to get these in. Cant understand why i dont get it, everyone says there so simple..Please tell me you can help me out. Ill paypal ya $5
Physically into the projector? You'll probably have to grind down the hole in the projector a little bit on the sides. PM me your number and I'll call ya... Have my old harness in hand...
ok the two that say where do these go... What you do is u take out the bulb that exists in the housing now and there will be one wire connected to the bulb and then one connected to the mount.. Disconnect both of them. Then you plug the blue and black wires into the two wire that you just disconnected.
Snip off the connectors on the blue and black wires going to thru the rubber plug. Pull those wires thru the plug. Now, on the harness (9007 plug) that came with the projector, you have a red and black wire setup, that goes to your 9005 high beam bulb...
Now you have 2 other wires coming from that 9007 plug a blue and black wire, with female spade connectors. You have the other set of wires (blue/black) that you just removed from the rubber plug, connect the blue to the blue and black to black... (I'd just remove the female spade connectors and just tie them together or the time being and covered with electrical tape)
The connector at the then end of the blue/black wire gets plugged into ballast...
Its 10:50 here and i have a game tomorrow. But i dont have my car anyways cause the hood is getting painted .. I can take pictures on friday for sure for you.. but please please dont snip at anything
There are two female connectors on the H1 Bulb.. one on the back of the bulb and one on the little bracket that holds the bulb in place.. Pull both those off the bulb and connect to the Blue and Black male connectors on the HID Wires
