Thread: 97-03 Digital DIC & Digital HVAC Swap Question
Results 1 to 9 of 9
  1. #1 97-03 Digital DIC & Digital HVAC Swap Question
    SE Level Member StreetChariot's Avatar
    Cowtown, OH
    Hello. I am interested in swapping out the stock SE DIC with the GT digital DIC. What must be done to get the digital unit to function properly?
    I am also interested in swapping out the analog HVAC control to the digital dual climate control. I have heard that a second diverter and blower has to be installed on the passenger side floor board. Is this correct?
    Thanks
    StreetChariot
  2. #2 Re: 97-03 Digital DIC & Digital HVAC Swap Question
    GT Level Member BackInBlack's Avatar
    Vermont
    The DIC is easy. 97 only swaps with 97, 98-02 are compatible, 03 only swaps with 03. You may even have the wiring connectors in your car, taped up and hidden.
    The dual climate control will require you to gut out your interior all the way to the firewall. I've only heard of 2 people taking the time and effort to do this.
    To the mods: Am I allowed to link to all my info over on CGP without breaking any rules?
    The GPs are long gone...
  3. #3 Re: 97-03 Digital DIC & Digital HVAC Swap Question
    Cowtown, OH
    Sounds good. I have a 2000 GP SE. I've been looking online for info, but everyone says that the 00 model did not have the harness. The car is out having a engine transplant at the moment, so I cannot take it apart to look. I am hoping to get information so I know what to look for.
  4. #4 Re: 97-03 Digital DIC & Digital HVAC Swap Question
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    Quote Originally Posted by BackInBlack View Post
    i know i'm no mod, but i've not seen any objections to linking back over there, but there are an ever increasing number of people that are banned over there and cant see the info you may post....
  5. #5 Re: 97-03 Digital DIC & Digital HVAC Swap Question
    Cowtown, OH
    So as long as I get one from a 1998-2002 model I should be good?
    Should I have the harness I need inside the dash? Do I need to splice into any wires in the column for VSS?
    Is the reason why they are incompatible that the TCS button is lacking on some models, (Pre-98), and that the TPS (Tire Pressure) info is on the 2003 models?
  6. #6 Re: 97-03 Digital DIC & Digital HVAC Swap Question
    Vermont
    97's get fuel level data directly from an encoder in the instrument cluster. 98-03 use the data bus, but 03 has a different data format or register location.
    IF you haven't been banned from CGP yet, here is more info:
    ClubGP Message Forum troubleshooting
    ClubGP: Photo Album
  7. #7 Re: 97-03 Digital DIC & Digital HVAC Swap Question
    Cowtown, OH
    Thanks for the great info... Lucky for me I hadn't been banned yet.
    I saw on one of the posts what looked to be a blue 8 position LED showing "P". Is this for the PS option on GT/P models, or has someone added it to display the current shift position (P/R/D/3/2) ?
    I am interested in adding in some mods to the DIC, and that would be great if someone had already figured that out.
  8. #8 Re: 97-03 Digital DIC & Digital HVAC Swap Question
    Vermont
    Heh heh. That's my ShiftView device that I used to sell. (Actually, I still have a bunch left...) You can read up more on my web site.
  9. #9 Re: 97-03 Digital DIC & Digital HVAC Swap Question
    Oklahoma
    You know, with my GP down awaiting a tranny transplant, it would probably be a good time for me to get one of those from you and send you my DIC so you can put it in your Bridgeport, LOL
  1. HVAC help
    By 3800SE in forum General Tech Discussion
    Last Post: 03-07-2010, 07:02 PM
  2. No hvac control
    By Onthebrinc in forum General Tech Discussion
    Last Post: 03-23-2008, 03:24 PM
  3. Need For Gen V swap ?
    By Meemperor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2008, 04:20 AM
  4. hvac control
    By Chleby in forum General Tech Discussion
    Last Post: 01-17-2008, 11:53 AM
  5. 97.5 pcm to 98 swap?
    By monte0 in forum PCM Tuning
    Last Post: 01-07-2008, 10:09 AM
