where can you get the concrete anchor?
got it at menards, redhead sleeve anchor, any place should have em
3" (or 4") long x 1/2"
ITW Red Head Dynabolt Sleeve Anchor
where does it need to be clearanced, etc....could you post more details ??
if you look at the pic youll see the three side slots are opened up, i used an 1/8 inch wide cutoff wheel with the sleeve removed from the bolt.
i also ground the leading edges into an arc with a taper to better insert it even after the first use/removal. the end of the bolt was ground with two flats to match the cap.
Thanks man its because I have been all excited about rebuilding my motor and Im having difficulty removing the main caps...had no idea they were pressed in lol...Got one off (#1) but cant get the others off...gonna try pounding on the crank with something(got a new one anyways)
glad to hear the 2x4 trick worked fer ya. remeber to not overtighten the sleeve anchors, sneak up on the tq, the worst that happens is they slowly pull outta the cap while using the slide hammer, if you overtighten them you can twist the sleeves and make it a pita to straighten em out to reuse... i've yanked 8 maincaps so far and they are pretty beatup but at 2.50$ for the two anchor package, overall its pretty cheep.
