Thread: Car Shuts Off When Engine Warms Up
Results 1 to 18 of 18
  1. #1 Car Shuts Off When Engine Warms Up
    SE Level Member 1999GTP1999's Avatar
    Toronto
    I have a 1999 Grand Prix GTP. When the engine is cold the car starts up perfectly. It will keep a solid idle, but when the engine warms up it cuts off. I've changed the fuel pump, fuel pump resistor, the battery, and the fuel filter. When I scan it for codes nothing comes up. I also checked for a vacuum leak, but there doesnt seem to be any. Could this be a bad crankshaft position sensor, throttle position sensor or camshaft position sensor? Or is it something else? Any ideas would be greatly appreciated.
    Thank you in advance
  2. #2 Re: Car Shuts Off When Engine Warms Up
    Jul 2008
    sumter,south carolina
    i had a chevy blazer that did the same thing... would run great until it hit operating temp then it would bog down and shut off... no codes.. i was told it was the spider intake.. never followed up on it.. parted it out.
    02 GTP with mods 05 GP for DD
  3. #3 Re: Car Shuts Off When Engine Warms Up
    westfield ma
    I have a 97 gtp I changed what you did including cranckshaft sensor. it runs only if I tap the throttle. i also have no codes. thanks all info helpfull
  4. #4 Re: Car Shuts Off When Engine Warms Up
    Toronto
    Before you changed the crankshaft position sensor was your GTP acting up like mine? Also, aside from having to tap the throttle, after changing everything, does it run fine?
  5. #5 Re: Car Shuts Off When Engine Warms Up
    Toronto
    hmm...a spider intake. I'm not sure if I've ever heard of that, what is that exactly?
  6. #6 Re: Car Shuts Off When Engine Warms Up
    Jul 2008
    they dont have them on GP's ... i was just throwing that out there.
  7. #7 Re: Car Shuts Off When Engine Warms Up
    westfield ma
    the car still won`t run. I still have to tap the throttle to keep it running.
  8. #8 Re: Car Shuts Off When Engine Warms Up
    anyone try the IAC?
  9. #9 Re: Car Shuts Off When Engine Warms Up
    westfield ma
    what`s that
  10. #10 Re: Car Shuts Off When Engine Warms Up
    idler air control valve.
    Basically controls the amount of air coming in the engine at idle.
    It sounds like its failing when the throttle body warms up.
  11. #11 Re: Car Shuts Off When Engine Warms Up
    westfield ma
    I had taken that off to check.It had alot of carbon on it.I sprayed pb blaster to clean it up. I was tried to move it in and out. Got it to move in when I tried to pull out I pulled it apart. Now i need a new one now
  12. #12 Re: Car Shuts Off When Engine Warms Up
    Sorry, you did that say just now or you did that before?
    And call up your local wrecker and see how much it is for one.
  13. #13 Re: Car Shuts Off When Engine Warms Up
    westfield ma
    I was going to the bone yard to get a maf, tps,and iac. I was just playing to see if I could get anything to work while taking them off. Was not planning on breaking it . I have a bone yard down the street. it would have to be one of these??????????
  14. #14 Re: Car Shuts Off When Engine Warms Up
    Toronto
    Is it possible that it could be bad ignition module?
  15. #15 Re: Car Shuts Off When Engine Warms Up
    Toronto
    Took it to a mechanic...turns out it was the mass air flow sensor!
  16. #16 Re: Car Shuts Off When Engine Warms Up
    westfield ma
    Went to bone yard today. All 3.8 had missing mafs. must be a common problem with that being the only sensor taken off engines. I still don`t have a check engine light on. will try tomorrow at other yard. to see if they have one, if not I will bring it to a garage
  17. #17 Re: Car Shuts Off When Engine Warms Up
    For future reference, from what I hear:
    common MAF diagnostic test is to disconnect it and see if the problem persists or stops.
  18. #18 Re: Car Shuts Off When Engine Warms Up
    westfield ma
    found problem.... fuel pump resistor. my brother found a link on this site,that had a car with same problem. it had a test to jump resistor to check. the post even told of a recall they have with the grand prix. I just can`t find the resistor. thanks for all the help jim
  1. Starting engine on engine stand?
    By bbptech in forum Off Topic Discussion
    Last Post: 01-13-2010, 01:23 PM
  2. just shuts off
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2009, 12:16 AM
  3. Engine shuts down
    By jvee44 in forum General Tech Discussion
    Last Post: 06-23-2009, 01:38 PM
  4. when my car warms up...
    By myg00 in forum General Tech Discussion
    Last Post: 03-11-2009, 01:09 AM
  5. Car starts then as its about to Idle, car shuts off
    By fasterthenu2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2009, 05:51 PM
