Thread: Engine Revving after filter change
Results 1 to 5 of 5
  1. #1 Engine Revving after filter change
    Nov 2009
    Brooklyn NY
    I have a question. I recently changed out the stock filter in my GTP, for a high performance filter. Problem? The engine is now revving. I'll be stopped at light and the engine won't come down to 850 RPM, it'll stay at 1k and sometime even above. Then after say two seconds it will go down to the normal, but if I'm stopped too long or put the car into park, it will def rev back up to 1.2k or so and then calm back down. I noticed this in heavy traffic last night. Any thoughts?
    By the way the filter that I put in was:
    IF anyone has had this problem and fixed it. Please let me know. I have sneaking suspicion that it's letting too much air in and the supercharger is being worked to death because of that. BUT I'm a newbie to this and not quite sure what to do/think and how to proceed.
  2. #2 Re: Engine Revving after filter change
    Charles City, IA
    Check for a vacuum leak you probably bumped something off.
    SMGPFC Two Nipple General
  3. #3 Re: Engine Revving after filter change
    Donating Users kfish's Avatar
    Ohio
    vacuum line on the throttle body would be my guess.
  4. #4 Re: Engine Revving after filter change
    Nov 2009
    Brooklyn NY
    it was raining today, but tomorrow morning I will start her up and check. Just listen for a leak or is there a better way to pinpoint this? (if its the problem)
  5. #5 Re: Engine Revving after filter change
    Ohio
    spray carb cleaner. the idle will change when you spray it at a vacuum leak.
  1. Tranny fluid and filter change
    By chevyy1212 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-16-2010, 03:49 PM
  2. advice on tranny pan drop/filter change-trannyman?
    By Liquifire in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-30-2009, 11:45 PM
  3. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
  4. (Solved) Trannyman Help! im in the middle of trans filter change.
    By speedemongtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-08-2009, 02:30 PM
  5. open air filter in engine bay
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2008, 04:21 PM
