Thread: Cold problems
Results 1 to 20 of 36
  1. #1 Cold problems
    Canada
    -30 degree weather won't let my car start. battery is drained and will hardly turn over. i could fix this if i could get the hood open. the hood latch lever inside the car by the emergency/parking brake won't budge. kinda like it was never meant to move, so how can i get this dang hood open without destroying my car?
  2. #2 Re: Cold problems
    GT Level Member AdamBall's Avatar
    Wausau, WI
    Park it in a heated garage ^_^ No GP deserves to sit outside in the cold
  3. #3 Re: Cold problems
    GT Level Member VejGTP's Avatar
    USA
    Maybe it's frozen shut?
  4. #4 Re: Cold problems
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    mine is having the exact same problem other then the not running part. can anyone help us with this problem? ive gotten the hood open after pulling it in a heated garage for sometime. i put penetrating oil on the hood latch but i froze right back up. help please
    silver 2003 Grand Prix GT List is on it's way to be updated
  5. #5 Re: Cold problems
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    my car says to put it in a garage....seriously its freakin cold.....29* is our high today. suppossed to be really cold rest of the week. your car will luv u for it.
  6. #6 Re: Cold problems
    Charles City, IA
    Quote Originally Posted by badbrad View Post
    29* cold? I was working out side today and it was -13* -30* with windchill.
    SMGPFC Two Nipple General
  7. #7 Re: Cold problems
    Apr 2009
    stockton ca
    If only for the weather I love california lol
  8. #8 Re: Cold problems
    Canada
    yeah well heated garage is out of the picture for me. so its probably frozen? maybe ill pop it in neutral and put some space heaters by the car, where should i focus the heat?
  9. #9 Re: Cold problems
    Charles City, IA
    The front hood latch.
  10. #10 Re: Cold problems
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    around your hood and latch
    or what he said lol
  11. #11 Re: Cold problems
    Apr 2009
    stockton ca
    Ive seen standard block heaters that heat the engine bay enough to stop that problem
    its also a off the wall idead but maybe some kind of weather proof heating blanket
  12. #12 Re: Cold problems
    Nov 2008
    whats causing that damn latch to freeze up. ya i know cold but i thawed it out and it froze again. has anyone found a fix for this? im going back to college friday and id like to be able to consistantly be able to get under my hood before i go back
  13. #13 Re: Cold problems
    PA
    Quote Originally Posted by kjohnson View Post
    Probably water. Thawing it out won't do any good until you get the water out whatever is freezing. Thaw it out again and give it a good coating of WD-40.
    2001 GSE
  14. #14 Re: Cold problems
    SE Level Member jshifti33's Avatar
    South Bend, IN
    I had the exact same problem. The battery was dead when I went to start the car the other morning. 'No problem', I thought, 'I'll just pop the hood give the battery a charge'. Hood frozen key stuck in ignition. What I did was remove the front grill and pop the hood latch with a screw driver. Once the battery charged, the car started, and once it was warm the hood latch un-froze.
  15. #15 Re: Cold problems
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    It is always recommended that if you live in a climate with -30ยบ temperatures you should run a block heater. A frozen latch and dead battery could be the least of your problems.
    For all your 3800 needs:
  16. #16 Re: Cold problems
    GT Level Member hourang's Avatar
    commerce, mi
    try white lithium grease instead of wd40.
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  17. #17 Re: Cold problems
    Orange County, NY
    white lithium grease is a good suggestion.
  18. #18 Re: Cold problems
    Canada
    yeah ill be giving that a try, been driving the truck to school not budget friendly hehe
  19. #19 Re: Cold problems
    Jul 2008
    sumter,south carolina
    silicon spray is even better
    02 GTP with mods 05 GP for DD
  20. #20 Re: Cold problems
    Nov 2008
    I thawed it out reall good and then soaked it down with penatrating oil and i still cant get the damn thing to work like its supposed to
  1. Cold Air
    By TallassJonG in forum 5.3L V8 (LS4)
    Last Post: 12-05-2009, 07:10 PM
  2. Plugs too cold?
    By dirtmaster88 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2009, 11:35 AM
  3. hello from cold ny
    By ASCStinger in forum Introductions/Noob Questions
    Last Post: 01-11-2009, 12:33 PM
  4. Cold Air Intake Problems.... HELP???
    By Gearhed42 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-06-2008, 05:56 PM
  5. Cold Air
    By jjwalton77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2008, 12:15 AM
