Thread: Gapping autolite 104's
Results 1 to 18 of 18
  1. #1 Gapping autolite 104's
    Windsor (ON) Canada
    I have just purchased some autolite 104's for my 01 GTP and I am just wondering what I should gap them at. I have searched this online with people saying they have gapped them at .050 .052 .054 and .056. with some people experiencing misses and slight tremors on idle.
    Anyone have any advice for a proper/best gap for 104's??
    Thanks!
  2. #2 Re: Gapping autolite 104's
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    I have mine gapped at 55. Never had a problem. What mods u have?
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  3. #3 Re: Gapping autolite 104's
    Joliet, IL
    biggest gap you can run with out blowout or knock....try .060 then if it blowsout or studders take em out and try .055
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  4. #4 Re: Gapping autolite 104's
    Windsor (ON) Canada
    Just a fender wall intake and 3.5 pulley.
    Another question: I'm looking at 8.5mm MSD and 10.3mm ZZP ignition wires, what are your thoughts on these?
  5. #5 Re: Gapping autolite 104's
    Donating Users Ibwrong's Avatar
    Oklahoma City
    I would look at exhaust work before I look at anything else..
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  6. #6 Re: Gapping autolite 104's
  7. #7 Re: Gapping autolite 104's
    Oklahoma City
    ^^ LOL
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  8. #8 Re: Gapping autolite 104's
    Windsor (ON) Canada
    I am gathering parts to be installed once the weather gets warmer. So when i DO get exhaust work which wires would you guys suggest?? (MSD 8.5 ZZP 10.3)
  9. #9 Re: Gapping autolite 104's
    Jul 2008
    sumter,south carolina
    dont really need wires until u get further down the road with mods.... im assuming u didnt se the links posted?
    02 GTP with mods 05 GP for DD
  10. #10 Re: Gapping autolite 104's
    Windsor (ON) Canada
    Actually I have seen the link posted.
    Looks like #1 on the list of typical maintenance is upgrading plugs (got that) and #2 is upgrading wires (hence my questions to you guys).... so what is this "further road" you are referings to?
  11. #11 Re: Gapping autolite 104's
    Donating Users kfish's Avatar
    Ohio
    get new replacement wires from the parts store. they work just fine
  12. #12 Re: Gapping autolite 104's
    Jul 2008
    Quote Originally Posted by Colossus View Post
    bigger wires arent needed for minimal mods other than looks... with the mods u have stated stock wires will be fine. steps 1-10 in that thread is a complte tune up... which should be done before any modding.
  13. #13 Re: Gapping autolite 104's
    SE Level Member mikesarebetter's Avatar
    Spearfish, sd
    new wires are not needed at all for these cars unless you got some issues with your stockers
    2003 GTP, pacesetter headers, colder plugs, zzp pcm for now, CAI, 3.5 pulley and 180tstat
  14. #14 Re: Gapping autolite 104's
    CT
    Yeah off ZZP's website you can spend I believe $30 on OEM wires instead of like $100 on aftermarket and they will work just fine for you.
  15. #15 Re: Gapping autolite 104's
    bigger wires dont do anything but look good and wear less when you take them on and off a lot. if you are just doing spark plugs changes every so often like a normal person then just get delco wires at your local auto parts store.
  16. #16 Re: Gapping autolite 104's
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    ac delco. best for the buck. no use in bigger unless u got money to spend, and if u do, send me some.
  17. #17 Re: Gapping autolite 104's
    Windsor (ON) Canada
    Thanks alot everyone. Just saved me some $$$......sorry badbrad lol
  18. #18 Re: Gapping autolite 104's
    Dec 2008
    hueytown, alabama
    your not earning any brownie point ya know!
  1. Autolite 104s
    By Bigbm80 in forum General Tech Discussion
    Last Post: 07-16-2009, 09:43 PM
  2. gapping 104's?
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2009, 03:05 PM
  3. Autolite 605's or 104's
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2008, 08:19 PM
  4. My autolite 104's are bad???
    Last Post: 07-03-2008, 03:30 PM
