I haven't seen one of these yet around here. I was thinking someone could get a list of torque specs for fastners on our cars. I am about to go through the top end of my regal and replace all the gaskets but I can't seem to remember the torque specs. I hope this was the right section for this.
Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
"New" 2007 Duramax ccsb with a few mods
#2
Re: List of Torque specs
GTP Level Member
03-19-2008
Fastener Tightening Specifications
Application
Metric
English
Accelerator Control Cable Bracket Bolt
16 N-m
12 lb ft
Air Injection Check Valve Pipe to Exhaust Manifold
10 N-m
89 lb in
Air Injection Check Valve to Bracket Bolt
25 N-m
18 lb ft
Balance Shaft Driven Gear Bolt
22 + 70° N-m
16 + 70° lb ft
Balance Shaft Retainer Bolt
30 N-m
22 lb ft
Camshaft Position Sensor Bolt
10 N-m
89 lb in
Camshaft Sprocket Bolt
100 + 90° N-m
70 + 90° lb ft
Camshaft Thrust Plate Bolt
15 N-m
11 lb ft
Canister Purge Solenoid Valve Bracket Bolt
50 N-m
37 lb ft
Canister Purge Vacuum Switch Bolt
50 N-m
37 lb ft
Connecting Rod Cap Bolt
27 + 50° N-m
20 + 50° lb ft
Crankshaft Balancer Bolt
150 + 76° N-m
111 + 76° lb ft
Crankshaft Main Bearing Cap Bolt
40 + 110° N-m
30 + 110° lb ft
Crankshaft Main Bearing Cap Bolt (Side)
15 + 45° N-m
11 + 45° lb ft
Crankshaft Position Sensor Stud
30 N-m
22 lb ft
Crankshaft Rear Oil Seal Housing Bolt
15 + 50° N-m
11 + 50° lb ft
Cylinder Head Bolt
50 + 120° N-m
37 + 120° lb ft
Drive Belt Tensioner Bracket Bolt/Nut
50 N-m
37 lb ft
Drive Belt Tensioner Bracket Stud
6 N-m
53 lb in
EGR Valve Adapter Bolt/Stud
50 N-m
37 lb ft
EGR Valve Inlet Pipe Bolt
29 N-m
21 lb ft
EGR Valve Nut
30 N-m
22 lb ft
EGR Valve Outlet Pipe Bolt/Nut
29 N-m
21 lb ft
Engine Block Coolant Drain Plug
30 N-m
22 lb ft
Engine Block Oil Gallery Plug
30 N-m
22 lb ft
Engine Coolant Temp Sensor
23 N-m
16 lb ft
Engine Flywheel Bolt
15 + 50° N-m
11 + 50° lb ft
Engine Front Cover Bolt Stud
20 + 40° N-m
15 + 40° lb ft
Engine Lift Bracket Bolt/Nut./Stud
30 N-m
22 lb ft
Engine Mount Nut Lower
78 N-m
58 lb ft
Engine Mount Nut Upper
78 N-m
58 lb ft
Engine Oil Pressure Indicator Switch
16 N-m
12 lb ft
Engine Wiring Harness Heat Shield Nut/Bolt
10 N-m
89 lb in
Exhaust Crossover Heat Shield Nut
20 N-m
15 lb ft
Exhaust Crossover Pipe Bolt/Stud
18 N-m
13 lb ft
Exhaust Manifold Bolt/Nut
30 N-m
22 lb ft
Exhaust Manifold Stud (Inner)
30 N-m
22 lb ft
Exhaust Manifold Stud (Outer)
10 N-m
89 lb in
Fuel Injector Rail Nut
10 N-m
89 lb in
Fuel Injector Rail Stud
25 N-m
18 lb in
Fuel Injector Sight Shield Bracket Nut
30 N-m
22 lb ft
Generator Brace Bracket Bolt
50 N-m
37 lb ft
Heated Oxygen Sensor
42 N-m
31 lb ft
ICM Nut
50 N-m
37 lb ft
ICM Stud
6 N-m
53 lb in
ICM Wiring Harness Bolt
2 N-m
18 lb in
Idler Pulley Bolt
50 N-m
37 lb ft
Idler Pulley Bracket Bolt
30 N-m
22 lb ft
Lower Intake Manifold Bolt
15 N-m
11 lb ft
Oil Cooler Adapter Connector
50 N-m
37 lb ft
Oil Filter
30 N-m
22 lb ft
Oil Filter Adapter Bolt
15 + 50° N-m
11 + 50° lb ft
Oil Level Indicator Switch
20 N-m
15 lb ft
Oil Level Indicator Tube Nut
19 N-m
14 lb ft
Oil Pan Bolt
14 N-m
125 lb in
Oil Pan Drain Plug
30 N-m
22 lb ft
Oil Pump Cover Screw
11 N-m
98 lb in
Oil Pump Screen Bolt
15 N-m
11 lb ft
Power Brake Booster Heat Shield Nut
20 N-m
15 lb ft
Spark Plug
27 N-m
20 lb ft
Starter Motor Heat Shield Bolt
30 N-m
22 lb ft
Throttle Body Nut
10 N-m
89 lb in
Throttle Body Support Bolt
10 N-m
89 lb in
Throttle Body Support Stud
6 N-m
53 lb in
Timing Chain Dampener Bolt
22 N-m
16 lb ft
Upper Intake Manifold Bolt/Stud
10 N-m
89 lb in
Vacuum Solenoid Valve bolt (with NC1 California Emissions)
10 N-m
89 lb in
Valve Lifter Guide Retainer Bolt
30 N-m
22 lb ft
Valve Rocker Arm Bolt
15 + 90° N-m
11 + 90° lb ft
Valve Rocker Arm Cover Bolt
10 N-m
89 lb in
Water Outlet Bolt
27 N-m
20 lb ft
Water Pump Bolt
15 + 80° N-m
11 + 80° lb ft
Water Pump Pulley Bolt
13 N-m
116 lb in
Wiring Harness Shield Bolt/Nut
10 N-m
89 lb in
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#3
WOW thank you very much, that was way more than I expected. Now maybe we can get a sticky made with that info in it.
#4
Might want to check out the How To Section as well....
http://www.grandprixforums.net/torqu...ifications.php
webracin
2001 Grand Prix GTP
ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
2000 Grand Prix GTP Daytona K&N, Flowmasters
#5
GTP Level Member
03-19-2008
haha, I didn't even know that was there. I stole it elsewhere. Same place that came from aparently.
#6
Donating Users
03-21-2008
#7
I need the specs for the valve body and pump bolts. Also those for the bolts holding the cover over the drive chains. Can anyone please help?
Thanks. Dan
#8
The mod from over yonder
12-04-2010
SMGPFC Two Nipple General
#9
What year does this apply to
I need them for a 2005 GTP
Doing a head gasket
#10
Banned
05-21-2020
OakdaleGTP
Doing a head gasket
These numbers will work for both Series 2 and 3 engines. The design of the supercharger/upper intake was the only major difference, and bolting everything down will be to the same spec. (source: just like many here, I've ran a 2006 GTP engine 11yrs for my turbo setup and 2006 LaCrosse engine 13yrs for my supercharged setup, both with combinations of Series 2 and 3 parts all over)
#11
Thank you
Question- the metal plate that is attached to the trans and engine (passenger side)
I cant seem to figure out how it goes on, can I go with out it
#12
Banned
05-25-2020
It should connect to the differential cover and the block behind the oil pressure sender. I'd put it on there for the support.
#13
Banned
05-25-2020
#14
Thanks
I put it all back together without the support bracket and it feels bumpy, it feels like the motor mount is bad
For this 2005 do I have to take parts off to fit it back on?
#15
Banned
05-26-2020
You may have to move the PS pump for access, along with the splash guard in the wheel well.
Also, check all your mounts to make sure they're snug.
#16
dezldave961
Thanks, that is what I was afraid of.
Can I drive it like this for a few days, I need it for work
#17
Banned
05-26-2020
It's not a big task... Pull wheel, 3-4 plastic retainers for splash guard, 2x13mm bolts thru PS pulley... Install 4x bracket bolts (loose at first to line them up, then snug down).
#18
Banned
05-26-2020
#19
05-28-2020
And.. on a 2005 you'll have a slightly different looking engine to trans bracket, but it ends up in the same place.
I tried to line it up for like 40 minutes before I put it back together
With no luck, I will try again this weekend
But now I have another problem, after driving the car for more than 10 minutes if I come to a stop sign the rpms stay high
Like the throttle body is sticking, I can hear the car revs high
What could be causing that
