Thread: Tips for removing rack and pinion
Results 1 to 6 of 6
  1. #1 Tips for removing rack and pinion
    Nov 2009
    Sheridan,Indiana
    Does anyone have any tips or a write up on removing the rack and pinion system on my 97 GP?
  2. #2 Re: Tips for removing rack and pinion
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    drop the k frame about 6 or 8 inches and you should be able to get at it no problem
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  3. #3 Re: Tips for removing rack and pinion
    Nov 2009
    Sheridan,Indiana
    Quote Originally Posted by Rather B Blown View Post
    Drop the entire K frame? Is there an easier way? I will be doing this in the garage on my back of course!
  4. #4 Re: Tips for removing rack and pinion
    GTX Level Member Deimos's Avatar
    iowa
    Should be 18's loosen the front up pull the rears completely. It's pretty cake it takes under and hour to man.
  5. #5 Re: Tips for removing rack and pinion
    Dec 2008
    London, Ontario
    yeah im pretty sure it has to be dropped a bit to get access to the rack. its really not as bad as it sounds. just jack the car up as high as you can and keep the jackstands as high as you can. There should be plenty of room.
  6. #6 Re: Tips for removing rack and pinion
    Nov 2009
    Sheridan,Indiana
    Do I need to support the engine from up top or will it stay in place with the jack under the k frame? Thanks for the replies guys this helps me alot.
  1. 04+ Rack and Pinion replacement [*]
    By UR LOSN in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2017, 01:31 PM
  2. Rack and Pinion Seal replacement
    By webracin in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2010, 12:24 AM
  3. Rack and Pinion Sweating??
    By jpom in forum General Tech Discussion
    Last Post: 08-26-2009, 11:19 PM
  4. Tips on removing excess RTV?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 08-21-2008, 10:25 PM
