Thread: help with wiring halo projector headlights
Results 1 to 14 of 14
  1. #1 help with wiring halo projector headlights
    GT Level Member pontiacGTP123's Avatar
    stanford Ky
    ok I got my halo projector headlights today, I bought them off ebay. Well opened them up and theres no damn directions for wiring the halos. in the pics of the headlight turned upside down you can see the wires for the two halos but what do I wire them to, I suppose the rest is just plug n play for the actual headlights.
    05 gtp- k&n open cone, intense tune, cat delete
    99 gtp- sold
    97 chevy 2500 diesel- heath turbo master, custom cai, 4" straight exhaust
    70 chevy c10- 6.0 swapped, still a project
  2. #2 Re: help with wiring halo projector headlights
    West Side Michigan
    When we got the halo's for my freind's camry there were no instructions either. I think there are two wires right? One of them is black for ground and the other is for power. We hooked up a switch between the power and the halo's so he can turn them on. I think that's how it's done..
  3. #3 Re: help with wiring halo projector headlights
    in a house
    Quote Originally Posted by pontiacGTP123 View Post
    You just need to power the Halo's, the rest is plug n play. You can either use the parking lights or the fogs to power them. Their is a write up here somewhere.
  4. #4 Re: help with wiring halo projector headlights
    GXP Level Member
    Theworld
    The halo's can be wired into anything really.
    I have mine wired into my parking lights, which also causes them to blink with my blinkers.. pretty cool if you ask me.
    Red = +
    Black = -
    On the parking lights, Green = Positive, Blue = Negative.
    Simply just splice the wires, and tie them in there together.
    As far as the headlights, you have to use your stock wiring harness. Unless you have HID's, but you'll need the harness for the other lights.
  5. #5 Re: help with wiring halo projector headlights
    stanford Ky
    yeah I would use the parking lights but when I use my turn signals wouldnt the halos flash?
    99 gtp- sold
  6. #6 Re: help with wiring halo projector headlights
    Tofu Delivery Boy Lsick7's Avatar
    MO
    I also wired mine into the parking lights, it's really simple. And yes the halos do flash with the turn signals, but it looks sweet anyway.
    Gold Digger - still broke, lawn ornament
    05 M6 PBM GTO - Corsa exhaust, aem intake, bmr drag bags. More whenever I haz monies
  7. #7 Re: help with wiring halo projector headlights
    Nov 2009
    Louisville, KY
    which halo's did you get on ebay?
  8. #8 Re: help with wiring halo projector headlights
    stanford Ky
    99 gtp- sold
  9. #9 Re: help with wiring halo projector headlights
    Kansas
    I have a blue brown and black wire coming out of the parking lights. Which are positive i know the black is negative
    SOLD 1999 GT Silvermist TS
  10. #10 Re: help with wiring halo projector headlights
    stanford Ky
    yeah i wired my halos to the brown(pos) and black(neg). They dont flash with the turn signals either, i like that better IMO. I guess the blue wire is the one that makes em flash
    99 gtp- sold
  11. #11 Re: help with wiring halo projector headlights
    Kansas
    I got em done too
  12. #12 Re: help with wiring halo projector headlights
    New York
    Hi I have a problem, I just installed my projector headlights but now everything is flickering , can somebody help me with this matter please?
  13. #13 Re: help with wiring halo projector headlights
    Commerce Twp., MI
    Check your wiring connections. It sounds like you are losing power somewhere in and out. If you put HID lights on and those are flickering, then you might need the power relay that connects them directly to the battery because they are not getting enough power.
  14. #14 Re: help with wiring halo projector headlights
    CHESTER,PA
    i had the same problem... i just spliced into my parking lights BUT my next problem is that i dont know how to wire my hid wire into them
  1. 97-03 Grand Prix Halo Black Projector Headlights
    By grandprix97 in forum General Tech Discussion
    Last Post: 03-02-2010, 09:59 AM
  2. New halo projector headamps with HID's.
    By Bedwards in forum Visual/Body Modifications
    Last Post: 12-13-2009, 03:59 PM
  3. Halo projector lights
    By Kingkee7 in forum General Tech Discussion
    Last Post: 12-02-2009, 07:48 PM
